Hitch setup analysis--F150 & Bigfoot 25B25RQ - Page 4 - Fiberglass RV
Old 07-20-2013, 12:29 AM   #43
Trailer: 2007 Bigfoot 25b25rq
Well, we just finished a 2 week, 2,000 mile drive with the new hitch setup. As far as I can tell it seemed fine and I never felt unsafe. It was fairly smooth, with a bit of soft bounce in the rear if the road got bumpy. With all tanks nearly empty, and therefore less tongue weight (probably closer to 10% than the 12-13% with full water), I seemed to get a tiny bit of wiggle out of the rear of the trailer in a particularly windy section of Central Oregon. The Equalizer brand hitch makes more noise than it used to now that it has more force on the bars, particularly in slow, sharp turns like within a campground (kind of embarrassing at times...). Part of this is from the bars sliding over the top of the rubber pads on the L-brackets. Once, though, the noise was from the pins that keep the bars on the L-brackets--the pins were getting gouged by the top edge of the square bars. I put a bit of grease on the edge and it seemed to fix it, but I am also going to purchase the new "snap pins" that the company has recently come out with. The revision of this part indicates to me that I am not the only one to have an issue. This never happened before when there was less weight on the bars.
The truck has the original shocks with 70,000 miles on them, so I might upgrade to a high quality aftermarket shock and perhaps that will control the rear bounce better, although I didn't find it objectionable as is. Also, Roadmaster makes a type of spring that assists the rear leaf springs. They are pricey but perhaps it might be worth looking into since I am running the rear axle at its maximum rated capacity. I plan to continue to tow with this setup but I now have a fairly clear idea about how careful I need to be about what and how I load.
Once again, I think the key lesson here is that the loaded weight of your trailer likely needs to be significantly less than the factory rated towing capacity for your vehicle. Perhaps a no-brainer for many of you, but I think some will find the difference in weight to be shocking. For example, for a 2004-2008 F150 you should probably keep the max loaded trailer weight 2,000-3,000 lb. below the factory rating or else you are going to risk exceeding your GVWR if you load much of anything at all in the truck and trailer. Every rig is different--maybe you don't have a canopy, you have different options, you carry more/less equipment, etc.--so of course you should check it at a scale, but that is difficult to do if you don't own the truck or the trailer yet and so maybe this can be a reality check for those looking. My worry is that too many people will do like I did initially--look at the truck towing capacity (mine is 8700 lb.), look at the trailer weight (mine was ~5400 dry), and think "it's fine--I have plenty of capacity". It wasn't true, and I think it is a bit shocking that the max towing capacity was so much larger and yet wasn't enough. My guess is that a similar story is true for other tow rigs as well.
It was kind of funny how all of this changed how I look at other tow vehicles going down the road--I've seen a lot of them the past two weeks, and more than a few times I found myself thinking "that vehicle is overloaded..." Another thought was that while in the fiberglass RV community our Bigfoot seems huge, it is still among the smallest trailers I saw on our trip. So many monster 5th wheels and 1-ton trucks...
Derek
Derek Johnson is offline   Reply With Quote
Old 07-20-2013, 02:32 PM   #44
Night Sailor's Avatar
Connecticut
Originally Posted by Jared J View Post
So, what do you perceive the difference to be in a fifth wheel dolly vs. a center pivot axle? Same end result, if you ask me.
Backing up is more difficult with the dolly type horse trailer. Impossible might be a better description. They work great going forwards.
Old 07-20-2013, 02:38 PM   #45
Jared J's Avatar
Trailer: 1984 19' scamp
Kansas
I don't agree with that at all, there's no difference between the two.
Old 07-20-2013, 03:55 PM   #46
Brian B-P's Avatar
Jared, if you find no difference between backing up a fifth-wheel trailer (with only one pivot point) and a full trailer or trailer+dolly (with two pivot points), I look forward to the YouTube video demonstration
Old 07-20-2013, 10:59 PM   #47
Jared J's Avatar
Kansas
We were discussing the difference between a fifth wheel with a dolly, and a trailer with a center pivot front axle. Again, I would like to know the difference. I find none. They will back up the same.
Old 07-20-2013, 11:22 PM   #48
Brian B-P's Avatar
Sorry!
I read fifth-wheel and somehow missed the dolly part. I agree, a fifth-wheel trailer with a converter dolly (typically a fifth-wheel semi-trailer) is exactly the same as a full trailer with a centre-pivot steering front axle.
bigfoot
CA - 2006 Bigfoot 25B25RQ Cathy P. Referrals: Molded Fiberglass Trailers 0 06-12-2013 11:29 AM
5th wheel hitch and crew cab setup mfsray01 Towing, Hitching, Axles and Running Gear 40 10-23-2012 09:36 AM
MT | Bigfoot 25B25RQ available $19950 Hugh in Montana Classified Archives 7 08-16-2012 12:47 PM
Shower Modification Bigfoot 25B25RQ Bigfoot Mike Modifications, Alterations and Updates 18 05-29-2009 10:38 PM
