Hitch ? Where to install? - Fiberglass RV
Old 09-15-2013, 05:27 PM   #1
McKenna Lynn's Avatar
Trailer: Considering Scamp 13
Considering Scamp 13 ft, deluxe, with tongue weight 160 and dry weight 1750 per internet.
TV would be 2011 Subaru Outback 3.6R, max tongue weight 200, tow capacity 3000 lbs. I would trying to ride light to match 200 tongue weight with 2000lbs. No water when driving.
I am new to this, and have not towed before. Where do I have hitch installed. Subaru or independent?
McKenna Lynn is offline   Reply With Quote
Old 09-15-2013, 05:44 PM   #2
MCDenny's Avatar
Trailer: Lil Snoozy
Either would be fine, Indie would probably be cheaper. Actually its not much of a DIY project. The trailer wiring just plugs into your cars lights, no cutting or splicing.
MCDenny is offline   Reply With Quote
Old 09-15-2013, 05:46 PM   #3
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
A dealer would probably send it out to a hitch shop anyway. I'd look for hitch shops in your locality and check Yelp or similar to see if they satisfy their customers.
Old 09-15-2013, 06:49 PM   #4
MC1
MC1's Avatar
A good hitch shop is what I would look for.
0r a reputable RV dealer that has a good reputation for installing and setting up vehicle/trailers.
Old 09-15-2013, 06:53 PM   #5
Borden's Avatar
Name: Borden and Carole
Smile Wish you lots of fun
Common loads:
1 7/8
Class I hitch does 200/2000
Class II 350/3500
2" draw bar
Class III 400/4000 common but can be 600/ 5000 plus
We used a class I with our smaller prior trailer and added a sway bar plate really helps.
Class III hitch is what we have now ours is a frame hitch type: car load limit is the new limit. (Our car was custom ordered with extras for towing)
We use 180 lbs. as our hitch weight trailer is 2190 lbs. with water and propane add gear for final total but we travel light.
Propane 20lb tank (38.5 X 2) and battery 115 lbs. remove the tanks and I can move the trailer around the yard
For cars tongue weight can be set to 8% but higher trucks need 10 to 15%, The Expert told me is depends vehicle height.
Class III is more than you need but is great to have.
Consider adding trailer brakes as well any load over 500 lbs. and it is just a good idea.
Check out the rules for your area as the law varies in different locations but in Ontario if the trailer weight is 50% or more of the tow vehicle weight, brakes are required.
1978 Ontario made Boler
Old 09-15-2013, 06:53 PM   #6
Perry J's Avatar
Trailer: 16' Casita
U-Haul probably installs more Hitches than anyone and are set up to do it quickly and cost effectively.
I've had several U-Haul hitches over the years and have never had a problem.
Old 09-15-2013, 06:57 PM   #7
Borden's Avatar
Believe Subaru give the 8% amount for tongue weight
Old 09-15-2013, 07:08 PM   #8
MC1
MC1's Avatar
Nice.... this is what we are using too. The other benefit of going with a 2", class III or better is that we can safely use a hitch style bike rack.
Old 09-15-2013, 07:19 PM   #9
Trailer: 2014 Escape 21
Virginia
Lynn
The Subaru hitch is one of the best looking hitches, but it is also the most expensive and the most difficult to install because the rear bump wrapper has to be removed. The other issue with the stock hitch it has the smaller opening (1.25" I think). Not only is the weight rating lower but most accessories (bike racks) work better with the 2" hitch receiver.
Most of the after market 2" receiver hitches hang below the bumper and are very visible on the Outback. On the Outback Forum someone posted about the Torklift Stealth hitch and a lot of people like it. I have a low hanging 2" Curt Hitch, if I were to buy one today I would buy the Torklift Stelth hitch. If you want to see an install check out Outback video.
Eddie
Torklift Central ECO Series-Stealth Trailer Hitches
Old 09-16-2013, 06:19 PM   #10
Brian B-P's Avatar
I agree... but the exception might be a genuine Subaru hitch, installed by the Subaru dealer as an accessory. I know that at least some Toyota dealers install Toyota hitches, and send vehicles out for aftermarket hitches.
There's no need for a genuine Subaru hitch unless it is different from the aftermarket models. In some cases, the "factory" or "OEM" hitch - the one from the vehicle manufacturer - fits up better into the bumper, usually requiring bumper cover modification. The Subaru owners here could provide guidance on this specific to the Outback; Eddie has already started.
Old 09-16-2013, 06:22 PM   #11
Brian B-P's Avatar
The 1.25" opening is normal practice in the towing equipment industry for up to Class 2 (3500 pound) trailer capacity... which is significantly more than the Subaru can handle, so it's more than enough.
The availability of good bike racks, and even a broader range of ball mounts, is a more significant factor in the 1.25" versus 2" choice.
Old 09-16-2013, 06:24 PM   #12
Brian B-P's Avatar
I would check the vehicle owner's manual on that - some require additional bracing (such as straps) to reduce bouncing of loads on racks regardless of the size or capacity of the hitch.
Old 09-16-2013, 06:36 PM   #13
Brian B-P's Avatar
Common loads:
1 7/8
Class II 350/3500
2" draw bar
A couple of tweaks:
  • The smaller receiver box size is 1 1/4", not 1 7/8".
  • The receiver box size is not part of the class definition, although 1.25" for Class I and Class II, and 2" for Class III, are typical.
  • The tongue weight (the number before the "/" in Borden's capacities) is not part of the class definition.
  • The Class III limit is 5000 pounds, even though some hitches are not rated for the full class limit.
... ours is a frame hitch type
The alternative to "frame" hitch would be a "bumper" hitch - you can't get a bumper hitch for a modern car. Current hitches do vary in exactly how they attach, and you certainly want one attached to the most appropriate point in the vehicle structure. Fortunately, any of the available hitches for the 2011 Outback are secured by four bolts through factory-provided holes into the frame rails.
Old 09-16-2013, 09:52 PM   #14
So I need a Class II hitch and trailer brakes. What would be the advantages of a Class III for me, if I would not be upgrading to a heavier trailer in the future.
5th wheel hitch to hitch pull jackstrr Towing, Hitching, Axles and Running Gear 9 07-19-2011 04:19 PM
"U-Hitch" Rear Hitch Receiver Tim Ryce Modifications, Alterations and Updates 9 03-12-2009 04:05 PM
Trailer Hitch Install needed - Vancouver BC Booker B. Problem Solving | Owners Helping Owners 7 06-27-2008 10:37 AM
Hitch Aid / Bumper Guard Behind Hitch Ball? Parker Buckley Problem Solving | Owners Helping Owners 12 01-27-2008 03:05 PM
Hitch install questions Quint Care and Feeding of Molded Fiberglass Trailers 19 01-18-2006 11:29 AM
