How Heavy is She? Trailer Weight - Fiberglass RV
Old 07-31-2018, 05:02 PM   #1
Markz's Avatar
This is a chance for you to post the weight of your RV and why it's so heavy or so light.
Rules.
List:
1. Type of RV and length
2. Your RV's weight
3. Why you think it's heavy or light for its type.
Sent from my SM-G930V using Fiberglass RV mobile app
Markz is offline   Reply With Quote
Old 07-31-2018, 05:05 PM   #2
Steve L.'s Avatar
Isn't this a sort of rehash of the trailer weights in the real world thread?
Without adult supervision...
Also,
Old 07-31-2018, 06:25 PM   #3
Trailer: 13 ft Scamp
Sure sounds like it
Old 07-31-2018, 06:54 PM   #4
Markz's Avatar
Not familiar with the tread
Please post link.
Old 08-01-2018, 06:51 AM   #5
ShelbyM's Avatar
Trailer: Casita SD
This http://www.fiberglassrv.com/forums/f...rld-43010.html You can ask a mod to delete your thread.
Old 08-01-2018, 07:42 AM   #6
Jon Vermilye's Avatar
Trailer: Escape 17 ft Plan B
And with Frederick's permission, I keep a editable, searchable & filtering spreadsheet version with many additions at http://lakeshoreimages.com/spreadsheets/Weight.xls.
If you want to add your trailer weight, I'd appreciate it; just email the info.
Old 08-01-2018, 11:00 AM   #7
Accuracy of weights
keep in mind that all those weights were taken on different scales, with varying degrees of accuracy. So the comparisons on the chart are approximations.
Real world scales will lose accuracy with age and a build up of dirt.
A scale must be "zeroed" before each weighing.
When you're weighing individual axles, especially on a balance scale, the approach and departure ramps must be level with the scale deck.
DO NOT hold the brakes, or turn the steering wheels. that can affect the reading.
Your most accurate reading is with the entire rig on the scale.
The separate axle weights should add up to within 1/2% of the total weight.
For the trailer: if you can, place it on the scale, unhitch the TV, move it off.
That will be the gross trailer wt. Hitch up, weigh just the trailer axle(s).
The difference should tell you the tongue weight.
Old 08-01-2018, 11:09 AM   #8
One or the biggest problem with attempting to be accurate is that the weight of a tow vehicle and/or a travel trailer changes all the time. So any weight is approximate. If you're well within the weight limits of your tow vehicle you can tolerate the differences. If you're near or at the limits it might be a good idea to change something so that you have wiggle room.
FYI Commercial truck scales along highways weigh in 20lb increments.
Old 08-01-2018, 07:55 PM   #9
Steve L.'s Avatar
Not that Fred needs me to speak for him but I believe most (not all) of the measurements are made by Fred. Fred deals with scales professionally. He's bought professional scales. For the most part I would not attribute much of the variation to the scales themselves. CAT scales are also probably pretty repeatable although our trailers are probably near the bottom range of the scales' range.
I think Byron's points are closer to the heart of the issue. So many other variables to confound the results. I tend to look at the min and max weights and standard deviation of the samples to get a feel for the scatter.
If one can find a trailer at the bottom of the sample range that just meets the tow vehicle's maximum I think you are misusing the data.
Also,
Old 08-01-2018, 11:46 PM   #10
Markz's Avatar
Will do
Maderator please delete this thread.
Old 08-01-2018, 11:53 PM   #11
Markz's Avatar
Originally Posted by alan H View Post
Sure sounds like it
Mod.: DELETE THREAD
weight
help - I am interested in buying a small, light weight trailer- total weight 2000 pdd pwedd Hi, I am.... 19 07-23-2011 12:50 AM
how heavy is too heavy for top bunk? PattiMurphy Problem Solving | Owners Helping Owners 2 06-06-2011 03:46 PM
Heavy duty electrical extension cord - Karalyn Problem Solving | Owners Helping Owners 16 06-30-2006 05:43 PM
Heavy Duty Bargman Legacy Posts Problem Solving | Owners Helping Owners 6 08-13-2003 05:47 PM
How heavy IS a trillium 4500?? Legacy Posts Care and Feeding of Molded Fiberglass Trailers 23 06-09-2003 01:26 PM
