How many jacks? - Page 2 - Fiberglass RV
Old 10-27-2011, 05:22 PM   #15
Greybeard's Avatar
Name: Richard & Carolyn
Trailer: 2000 Casita SD 17'
Gabriola Island, BC
Originally Posted by Rick G View Post
Hi Richard,
You have enough opinions to show that there are many possibilities, all of which will work. Like Byron and mcbrew, we use two rear jack-stand-type stabilizers welded on the back bumper that came with the trailer originally, which also level the trailer side to side to a modest degree. We lower the tongue until the rear stabilizers can be deployed, then raise the tongue back up to level. We have two tongue jacks installed, one on each side of the tongue (one with wheels). Using both tongue jacks usually allows us to level it side to side as well if the ground is moderately level. If not, I have occasionally put one piece of ĺ inch plywood under a wheel. Picture attached.
Unless there is something seriously wrong with the ground level, the whole process takes less than 5 minutes and provides a solid footing when we are inside. We donít lift the trailer enough to put the wheels off the ground, just enough to put some of the load on the rest of the frame. Easy and effective.
Rick G.
Thanks Rick
First, let me explain I have not had my new (2000) Casita out and was trying to figure out what I was going to do and how, when I first do venture out.
I have enough input now to know I was likely over estimating what I was going to need to do.
I am presently set up in my driveway which is not even and where I have had to make adjustments to make the trailer level even though we are only storing it here.
I was trying to determine why I the previous owners used front levelers (other than the tongue) if the manufacturer only provided 2 in the rear.
Now I know, its an option and I can use what I need to, if I am not comfortable or if I just want to :-)
Thanks again. Now I can't wait to get out!
Richard
Greybeard is offline   Reply With Quote
Old 10-27-2011, 06:22 PM   #16
Herb Sutton's Avatar
Trailer: 2002 Casita 17 ft Spirit Deluxe
Take it on a short trip to try it out. Bring a pencil and pad to note "surprises" that may turn up and mods that you might want to make.
I did that a year ago and found the wash basin was cracked in an inconspicuous place. My favorite RV parts store got me a new one in a few days. It is a generic part. The mods are ongoing but fun.
Herb Sutton is offline   Reply With Quote
Old 10-27-2011, 08:36 PM   #17
Greybeard's Avatar
Gabriola Island, BC
Good suggestion.
Thanks,
Richard
Old 10-27-2011, 09:02 PM   #18
I always used 4 "stack-a-jack" units on my Boler 17. My "new" Bigfoot has 4 "crank-down" units installed. (Hint - use a cordless drill to power them up & down - just like expen$ive power units!)
Old 11-15-2011, 07:16 PM   #19
Trailer: 84 16 ft Scamp
I probably shouldn't admit this but I need to 'shape-up' and 'clean-up-my-act', I can see!
When enroute, I have never used a jack. As long as the level is not so far out that the refrigerator doesn't work, I'm just fine. Guess this is because we also have a cruising sailboat and "level" is a word that isn't in sailboat vocabulary, but "heel" is! :>)
When disconnected from the tow vehicle I have a couple of those aluminum screw-type camper stands. I just set it somewhere under the rear bumper so when we both get in the back the tongue doesn't fly up.
That's what I like about the Scamp over the Avion that sits while the Scamp goes. With the Scamp, folks can fuss as much or as little as they want. We choose the latter and we love our Scamp! :>)
Old 11-20-2011, 08:03 PM   #20
Greybeard's Avatar
Gabriola Island, BC
Hi Richard,
Rick G.
Thanks to all for all the help. Now, just got to get going :-)
Richard
Old 11-20-2011, 10:02 PM   #21
Roger C H's Avatar
Smile If you are a First Nighter.
I would elaborate further on post #16 said.
Just stay in it one night in your driveway. That way, all the support you might need, more blankets, bathroom, shelter, etc. is right at hand.
Plus you will never camp cheaper!
I remember us trying to sleep in our sailboat on the trailer. Good thing we did it in the driveway. The mosquitoes found more ways to get inside than we could have guessed. Needless to say, we retreated inside the house forthwith.
Bottle Jacks vs. Scissor Jacks Jane P. Towing, Hitching, Axles and Running Gear 21 02-26-2011 08:17 PM
leveling jacks and storage jacks Ricky 4 Problem Solving | Owners Helping Owners 1 07-28-2008 10:29 AM
do i really need jacks Lori-Ann Towing, Hitching, Axles and Running Gear 7 08-20-2006 09:31 PM
Stabilizing Jacks... Kurt in BC Problem Solving | Owners Helping Owners 3 07-20-2006 11:33 AM
Stabilizing Jacks Kevin W Care and Feeding of Molded Fiberglass Trailers 14 06-12-2006 10:56 PM
