How much squeaking is too much squeaking? - Fiberglass RV
Old 05-22-2016, 08:01 PM   #1
My husband and I enjoyed our first outing of the year in our 1992 Scamp. We noticed when we were slowly driving around the campground, there was a lot of squeaking and creaking going on. As far as we are aware, the axle is as old as the camper. I know we are coming to the end of its life in our near future, but it seems ok in terms of the common "eyeballing" measures. Could we just need to lube the ball on the hitch? Is some creaking normal? We couldn't exactly pinpoint where the sound was coming from, but it was loud & noticeable.
NedMac is offline   Reply With Quote
Old 05-22-2016, 09:10 PM   #2
David B.'s Avatar
Name: Dave & Paula Brown
Trailer: Lil Snoozy
Dawn, our Scamp squeaked like you have described, and lubing the ball and locking assembly, and adding a "Hitch Vice" to the drawbar eliminated most of the noise.
Dave & Paula
Old 05-23-2016, 04:32 AM   #3
Raz
Raz's Avatar
Vermont
As well as the hitch, brakes make noise even when not engaged. Also I found the trailer noises more noticeable when I towed with my Subaru than with my truck.
Old 05-23-2016, 07:08 AM   #4
Thanks guys! Do you use a high pressure lube specifically made for that, or can you get away with anything, like bearing grease
Old 05-23-2016, 07:32 AM   #5
Raz
Raz's Avatar
Vermont
When unhitched I have a tennis ball on the tow ball to separate me from the grease. First of the season I put a glob of bearing grease in the tennis ball.
Old 05-23-2016, 07:38 AM   #6
WDH ???
when I got my trailer unsettling noises were coming from back there....smearing grease on the bars (the part of them that slide into the hitch body) cured the problem immediately.....
metal on metal....binbing....and these bars have to move sideways with every slightest turn.....
any grease would do....even bacon I bet....
Old 05-23-2016, 07:38 AM   #7
The squeaks may not even be coming from the trailer or the hitch. The noise may be coming from the springs/shackles, etc. (depends on setup) on the tow vehicle because you've got more weight on the back end than it's used to. My suggestion is to tow to a LARGE empty parking lot. Drive slow, slow... while someone is walking along side (outside) and listen for where the noise is coming from. Be CAREFUL and be SAFE.
Old 05-23-2016, 07:49 AM   #8
Trailer: 2008 Casita 17 SD
I don't know if you use one, but anti-sway bars will also make a lot of noise from the friction slide when you are driving around slow enough to hear it. Normally at highway speeds, it isn't a discernible noise, but they creak and grind a lot driving through camp grounds or parking lots, especially when turning.
Old 05-23-2016, 09:15 AM   #9
Name: Wayne & Barbara
Trailer: Parkliner
Iowa
Any trailer hitch store - even Walmart sells a hitch ball lube in a small jar.
It is white -ish probably a lithium grease. But any heavy grease will work.
They also sell a ball cover.
Old 05-23-2016, 10:21 AM   #10
Thanks everyone! Glad to know it most likely isn't anything serious. We will lube it up & likely try the parking lot method!
Old 05-23-2016, 11:53 AM   #11
TechiePhil's Avatar
Trailer: Freedom Express 192RBS
Alabama
Fastway e2 hitch
If you have the Fastway hitch with the anti-sway bars, the instructions say you should NOT lube the flat part of the bars that slide under the bracket with the cotter pin. That is the metal-to-metal friction that resists swaying. It also makes the most noise. Yeah, I greased it, then had to clean off the grease. But greasing the other ends near the ball and the ball itself does help with the creaking sounds.
TechiePhil is offline   Reply With Quote
Old 05-23-2016, 12:05 PM   #12
You make a good point - some of the newer none traditional WDH designs such as as yours, do not require grease at the bar attachment points as most traditional WDH do.
Old 05-23-2016, 12:18 PM   #13
Ohio
I spray some WD40 on the ball and hitch and it stops the squeaking and is not so messy
cmartin748 is offline   Reply With Quote
Old 05-23-2016, 01:15 PM   #14
Raz
Raz's Avatar
Vermont
I tried some of the Teflon lubrication products to avoid the mess but they didn't last very long before I had to reapply and I didn't want to carry the stuff with me. Your right though, grease is messy.
New Adjustable Torflex Axle Squeaking Problem lespnd Problem Solving | Owners Helping Owners 5 06-14-2012 05:25 AM
MOVING a TOO-TALL cramper into the TOO-SHORT garage! HeathGal Problem Solving | Owners Helping Owners 5 10-19-2010 02:36 PM
How much is too much?? Pamela H Problem Solving | Owners Helping Owners 10 07-04-2008 09:47 AM
You know you have too much stuff when.... Gina D. General Chat 12 07-10-2006 06:17 AM
How much is too much?? Legacy Posts General Chat 12 06-05-2003 08:31 PM
