user Brian also helps out by noting,
you need to distinguish between the actual weights and the ratings. Gross Combined
Weight Rating minus the actual Gross Vehicle
Weight (without the trailer attached) is the remaining capacity available for towing. If you just subtract ratings, you are assuming that the tow vehicle is loaded to its maximum, and it might not be.
Thanks Brian
