06-15-2019, 10:37 AM
Trailer: looking
How to feel in control going down hill?
Many would think this is someone that is really unskilled at pulling a trailer or even driving an RV, but I find going downhill, I start picking up speed and I can’t really figure out how to manage that.It actually can be quite frightening for me. Any tips would be appreciated .
06-15-2019, 10:44 AM
Trailer: '06 Scamp 16
Rochester, New York
Shift to a lower gear before starting downhill. DO NOT RIDE BRAKES!
06-15-2019, 10:50 AM
Trailer: Bigfoot 25 RT
What’s your tow vehicle?
Automatic transmission or standard?
Does it have a tow haul mode?
Does it have a tachometer?
06-15-2019, 10:55 AM
Trailer: looking
Toyota 4runner. 6. 2000. Automatic but I do have 2nd, 3rd and overdrive.
06-15-2019, 10:59 AM
What is your trailer (profile says "looking"). Does it have brakes?
Generally downshift (if the auto tranny allows it) and go slow.
06-15-2019, 11:00 AM
Quick answer is gear down.
Any chance your Toyota still has the manual that came with the vehicle? Toyota is very thorough in describing driving the vehicle. If you don't have it, search for it online.
06-15-2019, 11:03 AM
Trailer: looking
I will look at it. Thx!
06-15-2019, 11:04 AM
Trailer: looking
Thanks everyone! I think I probably just need to practice down shifting and learning when. Even when I am just in the Toyota going down a steep hill, I just pick up speed and it feels on safe. Thanks again
06-15-2019, 11:19 AM
Still dont know if your "Looking" trailer has brakes. If it does not, adding brakes is the first thing to do get better downhill control. Dont keep on them as that can cause overheating and fade, but slow down enough to downshift.
06-15-2019, 11:50 AM
When going downhill you should brake firmly in short bursts to take off several MPH with time in between applications to allow the brakes to stay cool.. Of course engine braking to help keep the speed down.
06-15-2019, 12:46 PM
If it has a tachometer, try to keep the rpm of the engine no higher than 4,000 when choosing a gear to use. Less stress on the transmission and less heating of all the engine fluids.
06-15-2019, 01:08 PM
A Scan Gauge is a useful tool to monitor critical temperatures like transmission, coolant, and such. These numbers become more important when towing in the mountains.
https://www.scangauge.com
06-15-2019, 01:25 PM
Trailer: 2013 Escape 19
+100 What trailer and does it have brakes? Brakes on a trailer are a huge help downhill. Many vehicles you should not be in overdrive, check your manual.
06-16-2019, 12:35 PM
Another "trick" is to use the same gear going downhill as it takes to go uphill
06-16-2019, 04:37 PM
Trailer: 2017 Escape 17B
SW Virginia
Assuming your trailer does have brakes you might try dialing them up some, especially if there's any feeling of being pushed.
Walt
06-16-2019, 05:05 PM
Test your trailer brakes in your driveway or on a side street, at slow speed.
If you don't feel any drag turn up the gain on the controller.
But not enough to lock the wheels. You want them to drag enough to keep the rig straight but not skid the tires.
06-16-2019, 10:51 PM
Trailer: 1983 Casita & 1972 home-built
Engine braking is the safe way to go downhill. Take it from a former school bus driver; if I can get to the bottom of the mountain without touching the brakes at all, that is success. Using your brakes heats them up so they don't work as well, and they can even get hot enough to fail entirely. You need cool brakes to make an emergency stop or even to make a turn at the bottom of the hill.
If your TV has disc brakes they will work better than the drum brakes on the trailer while getting overheated on a downgrade or repeated traffic stops. Drum brakes can fail entirely when too hot; then if you are going so fast you need trailer brakes to straighten out the rig, you won't have that option.
Slow down, use engine braking only, and save your brakes for an emergency. The only penalty for using a low gear is a slightly longer trip.
06-17-2019, 08:21 AM
Advice given is good. Go downhill in the same gear and at the same speed you would go up the same hill. Allow the engine to rev up and do the lion’s share of the braking, with short, firm bursts on the friction brakes as needed. Never, never, ever ride the brakes continuously. Make sure your trailer brakes are properly adjusted with the correct settings on the controller.
For those used to driving an automatic, you may not even be aware of what gear you’re in when going uphill, especially with never automatics having 6-10 forward gear ratios. Time to start noticing the downshifts. Also, newer transmissions vary in how they allow you to select gears manually. Spend some time reading your owner’s manual and practice without the trailer until you are comfortable with how your transmission works. Get help from a dealer or mechanic if needed.
If you misjudge the right gear at the top of the hill, and it starts to run away on you, brake firmly and downshift 1-2 gears. Repeat until only occasional braking is needed to hold a steady speed.
As a basic rule, if you don’t “feel in control,” you are going too fast in too high a gear.
