how to move scamp into tight parking spot - Fiberglass RV
Old 05-12-2013, 04:48 PM   #1
Trailer: 1986 13' scamp
I remember hearing about a some type of hydraulic jack ? to move a scamp around it had a wheel the attached to the hitch. Does anyone know what this is called? or does anyone have any suggestions I have a tight spot to keep the scamp in and not enough room to back it in with my car. It is also slightly elevated so hopefully it will move easily.
kayleigh0302 is offline   Reply With Quote
Old 05-12-2013, 04:59 PM   #2
Trailer: Scamp 16 Layout 4
Something like this: Trailer Dolly
kenl is offline   Reply With Quote
Old 05-12-2013, 07:13 PM   #3
excellent!!! thanks...
Old 05-12-2013, 07:21 PM   #4
Or something like this:
Haul-Master Item 39757 Moving Dolly, 1000 Lb. Hardwood
with a piece of plywood across the middle.
I have both, the trailer dolly is easier to use when pulling the trailer, the moving dolly , with the tongue jack resting on it, is easier to use when pushing the trailer, especially if you are going up any grade.
Old 05-12-2013, 09:14 PM   #5
George Nagel's Avatar
Trailer: 16' Scamp SD, TV: Tacoma 4cyl
Northern Wisconsin
I've been using one of the three dolly things used to move snowmobiles. Works well, but I think Mr. Miller's works as well and costs a lot less.
George Nagel is offline   Reply With Quote
Old 05-12-2013, 11:30 PM   #6
If that works for you that's great.
If you're on gravel it wouldn't work very good, the casters aren't large enough. Pushing the trailer up an incline on a hard surface with no means of braking other than your strength might not be a good idea. The Harbor Freight Trailer dolly and others like it have a skid that can do some braking, which I've had to use a few times.
Old 08-18-2013, 01:21 PM   #7
Trailer: 13ft Scamp
Wisconsin
I think the other plug on my truck is a 7 way , could I just het a 6way adaptor and plug it into the truck? Or will I still have issues since the 4 way isnt working..I did check bulbs and wires already and they all look good
Mcmarkrazz is offline   Reply With Quote
Old 08-18-2013, 01:50 PM   #8
Brian B-P's Avatar
This was a reply to an unrelated thread (Plug with camper doesn't work properly help needed please)... could a moderator please delete it and this reply?
Parking in a tight spot. Pat C Care and Feeding of Molded Fiberglass Trailers 5 08-20-2008 10:22 AM
How tight should this be? Kevin K Problem Solving | Owners Helping Owners 6 05-31-2008 08:39 AM
Parking in a tight spot Bob Radenbaugh Problem Solving | Owners Helping Owners 19 11-23-2007 01:55 PM
Tight spot Greg Yother Care and Feeding of Molded Fiberglass Trailers 17 04-16-2007 06:30 AM
