08-21-2016, 11:16 AM
#101
Trailer: '09 Scamp 13' w/ Bath
Well, my left brake is working fine, I don't really want to cut the cable and check if I don't have to.
It's the right brake that is not working. It appears to have power going to it, I'm just not sure if it is getting 'enough' power.
Based on a visual inspection of the right brake I am not surprised it is not working, it is pretty rusted out (compared to the left brake that looks almost new).... I just wanted to test for power as a 'last resort' before ordering a new brake.
Thoughts on if 4.97/5v sounds about right for a brake?
08-21-2016, 11:52 AM
#102
My controller can be set to max voltage of anywhere from zero to 12 (or the same voltage as the tug), so it depends on that setting, and also on how far I move the manual activation lever. My controller also shows the voltage so I can check that against the reading I get at the brakes.
YMMV
08-21-2016, 12:30 PM
#103
Ahhh. That makes sense. I didn't realize my brake controller settings directly related to voltage.
So, the controller was set at 5, and I got readings at 5... so it sounds like I am getting correct power. I can go back and read again at 2 and 10 just to compare, but if I am understanding you correctly, the power seems to be working correctly, and the brake is shot.
08-21-2016, 01:04 PM
#104
You could also check the voltage at the 7 pin connector on your vehicle.
08-21-2016, 01:07 PM
#105
I know the 7 pin is working because the driver side brake is working.
I got back under the trailer and tested the brake at 2 and 10, and the voltage on the multimeter corresponded correctly. So, unless someone has other thoughts, it sounds like the power supply is fine and the brake is shot (not surprised).
08-21-2016, 01:24 PM
#106
The voltage at the brake pin on the 7 pin should match the voltage you are getting at the brake assembly. If it does not, you have a bad connection in the brake circuit. If you have 4.97 at the brake assembly, you should have the same at the 7 pin.
08-21-2016, 01:46 PM
#107
Ok I will double check at the TV. I assume I stick the red probe into the slot that corresponds to brakes... is the center post the ground? Or do I just ground to the frame?
Edit* looked at wiring diagram, I see one of the 7 slots is the ground.
Thanks.
