I needa spare..what kind of rim fits? - Page 2 - Fiberglass RV
Old 09-05-2007, 09:08 AM   #15
Chester Taje's Avatar
If you guys are using automotive wrecking yard rims, be sure they can handle the pressures your trailer tires use, which are typically higher than automotive pressures. Rims do have pressure ratings and I believe they are stamped inside.
There's a lot more to this than just matching bolt holes; the centering (hub or lug), the offset and the 'dishing' (space on the back side of the rim) are all important.
I find this a real interesting tid bit.
Old 09-05-2007, 11:19 AM   #16
Brian B-P's Avatar
Pete's right about the importance of getting a wheel with safe ratings for all of the parameters. On an original-equipment wheel, I would not expect to find a lot of information... width, bead style, and even offset are common, but I don't recall seeing a pressure rating on one. Aftermarket wheels may say more, because they are sold without a specific vehicle in mind. Too bad the aftermarket wheel web sites have so little useful information: even a load limit is rare.
Light truck wheels seem more likely than car wheels to be rated for the 50 PSI inflation pressure of Load Range C tires, but most egg owners are looking for 13" and 14" wheels, and trucks use bigger stuff.
What kind of RV do I have? Adam L Problem Solving | Owners Helping Owners 15 05-09-2012 09:52 AM
Replacement Furnace - What Type Fits Michelle A Care and Feeding of Molded Fiberglass Trailers 3 04-25-2010 09:25 PM
What kind of TV do you have? Kevin K General Chat 34 08-26-2008 07:25 PM
One Of A Kind Benita General Chat 11 08-14-2006 03:14 PM
