We bought the 2003
Scamp used several months ago and personalized the interior with new carpet, cushions, upholstery and drapes. All the equipment worked as it should with the exception of the
furnace thermostat which was short cycling. I weighed the unit while loaded for a weekend camping trip. The water tank was half full. It weighed 2790. It is equipped with most options, 2
propane tanks, gr27 batt, AC, big
fridge, fantastic fan, etc.
The 13" wheels and Marathon
tires were in new condition, but 9 years old. The
tires are rated to carry 1300 + lbs. The tire rating scared me, due to being close to the carried
weight and the age of the rubber. I did some research and decided to try some Kumho 857's in the 185R14 with an 1874 lb. capacity. The diameter is 25.6”, so not too tall to fit into the Scamp’s wheel wells. I also ordered some zero offset aluminum Americana wheels with 5 on 4.5” lug pattern in a kind of retro style. When I got them mounted up I installed them on the trailer and found them to be a little too close to the trailer fender opening. Ideally I would need wheels with offset inward, or a shorter
axle. I decided to order a Flexiride
axle and install it under some 2” spacers to raise the rig. The Flexiride will need to be 65” hub face to hub face to fit the wider
tires inside the body. The ride height should end up 1/2 to 1” taller than with the stock Alko
axle. The Flexiride is also adjustable by rotating the trailing arms on the splines. It should be about right when set at the ideal 23 degree down start angle though. The new axle will be bolted onto the spacers instead of directly welded, so it can be changed at a later date if needed. Flexirides cannot be welded without damage to the core material. I am also considering relocating the new axle aft about an inch to get better tire clearance at the inner fender well front. This will also make the tongue
weight a little higher and help balance my rear bumper rack. I plan to order the axle tomorrow, so I will keep you posted how this all goes.
Russ
