Increasing the carrying capacity of a Trillium - Page 5 - Fiberglass RV
Old 11-29-2011, 02:41 PM   #57
While I understand that the average car can't handle as much actual tongue weight as a truck, and that a WD hitch might alleviate some of that, I simply don't understand the thought behind your last sentence.
Shouldn't the ball height be the same in either case?
Also... Is it wise to use a WD hitch on a unibody car? If so why?
Wouldn't a WD hitch move shift stress points forward of the hitch into the floor pan? Perhaps that would only be a problem on a few of the weaker ones?
If it were me I'd worry more about the strain on the trailer frame with additional forces caused by a wd hitch.
Old 11-29-2011, 03:10 PM   #58
cpaharley2008's Avatar
No weight distributing hitch is needed for 200 lbs tongue weight. The purpose of the w/d is to shift excess weight to the front to keep the weight evenly over the wheels, front and back. Two hundred pounds is light, more chances of sway with a light t/w. Sway control may be needed but no w/d.
Old 11-29-2011, 03:49 PM   #59
I suggest you study the workings of WD hitches.
They remove weight from the rear wheels of tow vehicle and distribute that weight to front wheels of tow and to the trailer wheels.
Old 11-29-2011, 03:51 PM   #60
Isn't that what I said in my post??
Old 11-29-2011, 04:00 PM   #61
Trailer: Trillium 4500 1977
Quebec
Initially I could carry my Trillium 4500 1977 to the car hitch with only one hand and found out highway driving on windy days made it unstable. With a second Propane tank and the addition of a RV battery, I have just enough weight on the tongue. I have a sway bar, but I don't bother to engage it anymore. I must have about 250 lbs on the tongue now. This is sort of proving your point.
Just a tip: in the past, with a tent trailer that was wide and short, I used to cancel occasionnal trailer sway simply by touching the manual button on the electric brake controller.
As it was pointed out in many other threads, WD hitch is NOT a good idea with a light RV and may even damage the RV frame.
Martin J. Qc Canada
lamimartin is offline   Reply With Quote
Old 11-29-2011, 04:33 PM   #62
IllAnnoy
I couldn't find the photo I was looking for, but I found this...
Notice the absent rear wheels.
Old 11-29-2011, 05:17 PM   #63
Isn't that a Olds Toranado? That like the Cadillac had front wheel drive for a couple of years. But the picture shows the effect of the w/d proper set up. Just think of that stress being placed on the frame and trailer!!
Old 11-29-2011, 05:24 PM   #64
What about the Citroen auto's - I remember Allan Funt on Candid Camera did a shoot with it going in a gas station and asking the mechanic to check tire pressure. The car was running on 3 wheels, the Citroen has pneumatic suspension, here
Old 11-29-2011, 05:32 PM   #65
The impression from this is that it shifts the weight to front wheels of tow vehicle only. However, if you really look at how it works, more of the weight is shifted to the trailer than the front wheels.
Old 11-29-2011, 05:35 PM   #66
In this case all the weight that was on the rear wheels is now added to the trailer weight. Think about the front wheels as a pivot point.
Old 12-01-2011, 03:20 PM   #67
David Tilston's Avatar
Back to the subject.
I talked to Joe Thoen at Team Trillium Trailers Manufacturing. He said to do an off frame restoration, which includes a new 3500lb axle, 2" coupler and chains, sand blast and paint the frame with DTM acid etch paint would be $1700. New 14" alloy wheels with good tires would be an additional $185/each.
What do you think?
Old 12-01-2011, 06:47 PM   #68
See above post.
Scott H is offline   Reply With Quote
Old 12-02-2011, 12:31 PM   #69
Originally Posted by Scott H View Post
That price is high; but maybe it's just the Canada thing. I went to a dedicated suspension shop and my bill looked something like this:
Dexter 3500#, EZ lube, 10" electric brakes- $388
2 fancy 14" aluminum wheels with tires- $320
1 white 14" steel spare with tire- $100
2"ball A frame coupler- $30
New sidewind jack- $44
2 BAL crank down stabilizer jacks- $57
New saftey chains with anchors- $25
Labor for everything plus welding on a new propane rack- $260
Total- $1230
I guess the price delta is in line with what I have observed previously.
Dexter axle: $400 vs $388 (103%)
Wheels: $370 vs $320 (116%)
My total: $2070 vs $1230 (168% and I don't need jacks!)
What was the hourly rate at the shop you had the work done at?
I notice that painting is not in your list. I assume that it was painted. What did they paint it with? Did they take your trailer off the frame?
Old 12-02-2011, 08:15 PM   #70
Trailer: 1971,1974 Boler 13 ft
$1000 for an axle replacement seems a bit steep to me....Too much labour $$$$
David Konduc is offline   Reply With Quote
trillium
Carrying generator gas rgrugg Modifications, Alterations and Updates 6 06-26-2011 07:21 PM
Carrying a canoe while towing a trailer; recommendations? Des Nolan Towing, Hitching, Axles and Running Gear 8 10-16-2010 05:43 PM
carrying bikes Rarebird Problem Solving | Owners Helping Owners 31 07-27-2009 07:55 AM
Carrying Bikes Lainey Problem Solving | Owners Helping Owners 8 08-29-2007 03:33 PM
Carrying the generator and fuel.... Lizbeth Problem Solving | Owners Helping Owners 18 08-12-2006 10:45 PM
