11-16-2011, 10:07 AM
#21
Trailer: 1974 Trillium 13 ft
Originally Posted by David Tilston
Sorry, total newbie, who is Tom, and how do I ask him?
Tom Young is the owner of Trillum RV. As far as I know he typically answers questions himself. See www.trilliumrv.com or try Sales (at) TrilliumRV.com
11-16-2011, 10:32 AM
#22
Trailer: 16 foot Scamp
Originally Posted by floyd
Stick to steel, It is much cheaper and a good aluminum welder is more difficult to find. You could have it powder coated or coated with POR15.
It will surely outlast your use for it.
Besides any future accessory would be easier to attach.
X3
Originally Posted by lamimartin
Hi David,
I fully agree with Floyd that a new steel frame is likely the best way to safely increase RV cargo capacity at a reasonnable cost on your Trillium 4500, preserving the sleeping space for your kids. Chasing a higher cargo capacity RV, often with heavier dual axle, is likely going to end up at a weight higher than the towing capacity of your vehicle.
Upgrading your RV frame should not significantly increase RV tounge weight, so any increased cargo capacity in the RV will reduce the truck rear axle load to safer levels. A professionnal can precisely match the final weight, desired load capacity frame gauge, stronger coupler, suspension and brake capacity. Instead of net reduction of 300 lbs on the rear axle (considering tongue weight), you may quickly fall back within safe load limits on all axles (truck and RV). This exercise will require a very high level of expertise and experience to properly balance all variables, design and weld together something that will work for you.
Good luck.
X2
Properly designed, an aluminum frame would be nice. To do it right would require real engineering and the cost would likely not be feasable for a one off trailer. Steel is more forgiving in design and easier to fabricate. Lamimartin brings up a very good point that bears repeating. Over building a frame can cause problems just like underbuilding. You will get a much better final result if you can find a trailer builder who can specifiy the right materials and design for the load. Some less sophisticated trailer builders just take the approach of "build it hell for stout". That's expecially true of utility type trailers that routinely get overloaded. You can look at some manufactured travel trailers with a similar GVW to your target for an idea. You may be surprised how lightly they are built. There is no point using up your towing capacity and gas dragging dead weight all over the country.
Of course one possible solution would be to sell your trailer and just get a bigger one. I would certainly run the numbers.
David
11-16-2011, 12:42 PM
#23
David
I have sent a RFQ to the folks at Trillium RV for a new frame. There current Trillium 1500 has a GVW of 2200 lb.
But, let me play devils advocate. What if I rebuild almost exactly the same frame, (the existing one is a bit rusty) except use slightly thicker square tubing, extra reinforcements around the bends under the front...etc. Just beef it up a bit. I am only looking for an additional 300 to 500 lb capacity. I realize that this is not proper engineering, but I think between my neighbor and I we could come up with a reasonable reinforcement that I would feel safe with. Not too much but, with the small increase in capacity I want, enough. This along with new axle, tires and hitch, and I should be OK. No?
11-16-2011, 12:58 PM
#24
If your present frame shows no apparent damage....
Ask the folks at Trillium about simply upgrading the axle and maybe the hitch.
11-16-2011, 02:19 PM
#25
That was my first plan!
No damage, but substantial rust. It has not perforated the square tubing yet. Since I want to carry a bit more then the current GVW, I would feel better with a new, slightly reinforced, one.
11-16-2011, 02:24 PM
#26
David,
Can you tell me what the tubing size is on the trailer now, including the wall thickness? I need accurate numbers. Also need the length of the frame (approximate), and the length from the hitch to the axle.
David
11-16-2011, 05:53 PM
#27
David,
David
I am a CAD geek, (6 years professional experience, 9 years ago). I will go home tonight and start a 3d AutoCAD drawing of the frame in its "as found" condition. Hopefully I will have it done tonight. The hitch and wheels may not be to scale, but close. I will post the results tomorrow.
Odds are that this will lead to an obsession to CAD the entire trailer to an unreasonable level of detail. Just who I am.
11-16-2011, 07:14 PM
#28
Dave, I love ODS people... it's nice to know I'm not the only one!
Looking forward to your "vision."
11-16-2011, 07:42 PM
#29
Trailer: Trillium 4500 1977
Quebec
The Trillium 4500 original frame was barely sufficient to be on the safe side, mainly because the square tubing has very thin walls. Rust will make it thinner and likely fail wherever there is possible metal fatigue, weak solder or improper design or assembly. Known weak points are at the axle level and at the junction of the under frame curving up to the hitch level. It is made to be light but not overloaded.
Adding a load of 1000 lbs in your RV, would reduce the rear axle load by about 750-800 lbs. Is it enough ? If your axle is original, it is likely unable to meet the full load specs anymore, because rubber components have degraded over time. It is certainly possible to get a slightly stiffer axle and upgrade the overall frame capacity to cargo capacity of 1000 lbs instead of 500. Welding rusty metal leads to premature failure and more rust. Unless you only find superficial rust, start new. It is hard to tell how much remains inside a square tube.
Martin J. Qc Canada
11-16-2011, 11:46 PM
#30
Canadian Regs
It seems there are regulations, no surprise there, covering modifying the carrying capacity of a vehicle:
Motor Vehicle Safety Regulations
Another factor is the strength of the frame, etc. These trailers are designed to be light and thereby are made of lightweight components. The trailer I had for my 1700# boat, which I figured weighed 300# in reality weighed 800#. Fiberglass trailers, especially the 13' ones, are designed to come in under 2000# so they can be towed by 2000# capacity vehicles, like mine. If you want to carry heavier weights, buy a cargo trailer that can handle the weight, and add the living accroutements.
As an aside, in my working days, I worked with a CAD program named CATIA. I probably wouldn't be able to use a current version of it after nearly 10 years.
11-17-2011, 02:27 AM
#31
The Drawings
I have finnished the drawings.
I had to borrow calipers from my neighbor to measure the wall thickness. 1/8" as suspected.
I had the trailer up on the rear jacks that the PO installed and the tounge jack. I asked him to come over for a look. Since I was concerned. He is as close to a trailer expert as I have ever met. He crawled under and took a look. His words were "Its practically brand new, just surface rust and not much." And I was worried, what do I know.
As has been previously discussed the claimed weight on this generation of trailers seems to be a work of fiction, the work of marketing. If many of the trailers on the road are over loaded when empty, (air conditioning, batteries, inverters, propane,....), and real people still put in luggage, food,.... Then there must be lots of these trailers traveling over loaded.
Why are they not crashing?
Is it possible that it is safe to opperate these trailers a bit over loaded on smooth pavement? Oh, I realize the response from many will be a big negative. It is in this thread. Why would any Joe user think that he knows more then the engineers that designed it? Or is possible that the engineers were designing for a level of abuse that the average egg owner does not subject their unit to? Since I don't plan to bounce down a rough logging road, in the mud, maybe I can carry the food after all?
Just thinking out loud.
11-17-2011, 02:36 AM
#32
I wish! I had dreams of working with Solid Works, but alas AutoCAD is the industry standard around here.
Did you work for NASA?
11-17-2011, 05:42 AM
#33
Quebec
That means, there is a provision in the law to INCREASE the capacity of an RV, but an ADDITIONAL label must be placed next to the manufacturer's label:
(i) the words “THIS VEHICLE WAS ALTERED BY / CE VÉHICULE A ÉTÉ MODIFIÉ PAR” followed by the name of the company that altered the vehicle,
That means the company that performs the modification can be held accountable if an accident is caused by the modification. and that any insurance company or new owner will be notified.
Thanks for finding out this reference. This is what I suspected when we first talked about a new frame.
It would be interesting to see how expensive it will be to find a company that will accept to make such label.
Martin J. Qc Canada
11-17-2011, 10:00 AM
#34
David,
David
I posted the drawings, but I actually did not answer your question. The sides of the frame are 1/8" 2"x3" square tube. The tubing has reinforcment at the point where the tubes bend inward. I have not put it on the drawing yet, but there appears to be gussets on either side of the tubes where the tubes bend toward the middle of the trailer and end just as they bend up. They are 1/8" thick and 24" long in total along the center of the gusset and 16" along the top and bottom. All other dimensions you requested should be on the drawings.
11-17-2011, 09:19 PM
#35
Proposed Mods to Frame
David,
David
Since I can't PM a drawing. Please take a look David.
11-21-2011, 06:17 PM
#36
Thought I would share an email Tom Young sent me the next day after I asked for a quote. I am a bit curious about him saying not to use a weight distribution hitch. Good price for a factory part:
Hi David:
The Trillium frames in production today are the same as in 'vintage' Trilliums.
You may consider replacing just the axle to 2500 lbs.
Things to inspect to evaluate the upgrade possibility:
Re-enforcement plates on the sides of the frame where it forms the upward bend at the front of the trailer body.
If you have the 1 7/8" coupler - that needs to be changed to 2"
Upgrade safety chains
Upgrade tires to 1360 lb. capacity
We are using Carlisle 'Sure Trail' ST 175/80 D 13
Check wheel capacity, but they should be OK
Have an experienced metal shop check for any problems, rust in the frame.
Complete frame, with 2500 lb. axle, brakes, 2" coupler, safety chains, propane tray, weld bracket for swing jack: $1750
Note: Be sure to keep a minimum of 10% load on the car. (Tongue weight)
Do not use a weight distributing hitch on new or old frames. - Sway control is OK.
Tom Young
Trillium RV
11-21-2011, 06:51 PM
#37
Quebec
This is great news. Unless there is too much rust on your frame, you should be OK.
I did a similar upgrade on my boat trailer. It was equipped with 2000 lbs capacity leaf springs, but sailboat equipment, gear and fuel load increased over time. The rusty 30 year old original leaf springs were weakened and no longer sufficient. I did replaced them with 2500 lbs capacity springs axle and new wheels, tires and hydraulic drum brakes and it now behaves like a new trailer. My square steel frame has no rust. In my case, the upgrade only required simple hand tools. In your case, you likely need to separate the fiberglass shell from the frame install the upgraded parts, and have a rust inhibitor treatment before you have it reinstalled.
Personnaly, I like to have a set of jacks installed at each corner of the trailer instead of using just the swing jack on the front, precisely because the flexible frame swings too much when it is only held by the swing jack. I welded upside down two automotive jacks I found at a scrap yard. I picked two that use the same hexagonal head (and the same manual crank) than the OEM jacks located under the rear bumper. It also makes leveling for the fridge much easier on uneven ground.
This is a bad idea if you want to keep minimal weight, but a good one if you like quick setup, convenience and comfort.
Martin J. Qc Canada
11-21-2011, 07:32 PM
#38
Hi David:
Tom Young
Trillium RV
Weight distribution hitches put a lot of strain not only on the trailer, but the hitch,receiver as well as the tow vehicle. That is why you normally only see them on heavy trailers with bigger frames and bigger tow vehicles. Picture you taking a 15' long iron bar, placing it 4' under your tow vehicle, have 4 strong persons lift up on the bar to raise the rear of the tow vehicle and then follow along the road keeping the upward pressure on the vehicle. That is what the w/d is supposed to do.
Here, the bar is your trailer exerting that lift/strain on your vehicle. So you can see why it is not recommended for a small trailer. Your frame would crack.
11-21-2011, 07:39 PM
#39
Hi David:
Tom Young
Trillium RV
Good news David! Are you going to keep your frame then or buy the complete rolling chassis? I agree that is a very reasonable price for a specific replacement frame.
The equalizing hitch puts more stress on both the trailer frame and the truck frame. On such a light trailer I would not use one. I doubt you could even find the correct spring bars for such a light application.
David
11-21-2011, 11:35 PM
#40
David
Well... I hate to have put Tom Young to the effort and not come through with a PO. It bugs me when that happens to me. But... as stated in a previous post, my frame is in good shape. The thickness of the open end of the tubes near the axle are, other then a thin layer of surface rust, 0.125" thick. The person I had look at it couldn't figure out what I was worried about. I may worry a bit too much.
Toms suggestions for increasing the strength of the frame are interesting to me!
"Re-enforcement plates on the sides of the frame where it forms the upward bend at the front of the trailer body."
My drawing before was a bit incomplete. The attached drawings show the plates that are welded to the frame, I assume this was stock.
I would really like to express my appreciation to Tom Young from Trillium RV for providing a quick and economical solution for a difficult problem that, it turns out,.... I don't have.
As far as I can tell, the frame has the suggested mods already. I will not go much over the 2000lb limit and I will drive modestly.
I do plan to change some things on the frame. I will replace the 1-7/8" coupler with a 2" coupler/chains, get 14" weight rated tires/rims, and then sand the rust off and Tremclad black. The whole trailer, other then the frame, is getting painted white with silver decals to match the tow vehicle.
The tow vehicle is a 1996 GMC Savana 1500 van with a 5.7L Vortec. Based on the receipts, it has seen a lot of suspension service in its 260 000km life. I plan to add air bags to the rear suspension. To support the overloading that a slightly over 2000lb trillium, and my family of seven will cause. I wish that they had used a 2500 van.
No weight distributing hitch.
Changing the axle may be necessary in time. I will perform some weight tests on the axle to judge its condition.
Has anyone here changed an axle on a Trillium 4500? How hard is it? Got any pictures?
