Installing a Equalizer WDH on 17' Casita - Page 2 - Fiberglass RV
Old 03-13-2017, 10:16 PM   #21
Mike Magee's Avatar
Trailer: 93 Burro 17 ft
"...need to add nearly 30 lbs. to the front" ... depends on your current hitch weight. Suppose your Casita weighs 3200 lbs loaded, with a hitch weight of 450. Adding 50 lbs to the rear makes the trailer 3250 and the hitch 420, which is still 13% of the weight and is more than enough for good handling. You should be fine even at 10% weight on the hitch, and you're planning to have sway control besides.
Old 03-24-2017, 09:06 PM   #22
WD hitch install
I cut off the short angle iron stops on the side sides of the propane mount with a reciprocating saw, ground off the remains of those ears and installed a 1/2 inch wood strip in the front and rear angle iron propane tank mount and set the tanks on the wood strips.
This allows mounting the WD brackets on the frame without torching off the end stops and possible damage to the frame. A little paint and all was well!
Frank F
frankcfx is offline   Reply With Quote
Old 03-24-2017, 10:06 PM   #23
Raspy's Avatar
Trailer: Roamer 1
Smith Valley, Nevada
Originally Posted by dmad1 View Post
According to my wife, I don't have anywhere near 32" and am just wishing...
Can't help but wonder; You may be wishing, but I'm betting she's glad.
casita
Equalizer hitch? Greybeard Towing, Hitching, Axles and Running Gear 26 02-12-2012 12:22 PM
Equalizer Hitch to Reduce Bounce? Scott S. Towing, Hitching, Axles and Running Gear 11 11-19-2009 09:16 AM
sway bars, equalizer hitch Francine P Towing, Hitching, Axles and Running Gear 18 11-14-2008 12:10 PM
RAV4 and equalizer hitch - any problem? Glenn Baglo Towing, Hitching, Axles and Running Gear 6 10-31-2008 02:49 PM
sway bars, equalizer hitch Francine P Problem Solving | Owners Helping Owners 0 01-01-1970 12:00 AM
