Originally Posted by Samwise
With nitrogen in the tires, they won't be sensitive to temperature changes like normal air is.
In a previous lifetime, I was a pilot for Boeing, and the tires on the airplanes were subject to extreme temperature changes - it's cold at 43,000 feet, and it's hot in desert areas. Our tires were always filled with nitrogen.
Guess you didn't take any chem or physics in your previous life. Nitrogen is affected by the very same gas laws as air, in the very same way.
Airlines would use nitrogen because:
1) It is easier to get as a dry gas. You don't want a blob of condensate water freezing onto the side-walls, and then becoming a unbalanced mess upon touch down.
2) While not an inert gas, it is more inert in the catastrophic failures that would endanger a plane. The lack of HP
oxygen won't feed a fire or decrease the lifetime of rubber or similar materials in the tire.
There are many video's out there that show the danger of welding on a tire rim with a filled mounted tire attched. Same thing could happen on an airplane, a small fire could turn the tire into a big bomb.
