Is this a bearing buddy? - Fiberglass RV
Old 04-19-2019, 01:35 PM   #1
Two years ago I blew out both bearings on the curb side of my 1997 Scamp 13. Flatbed towed to a trailer place, they fixed it and I went on my way.
Today I jacked up the trailer to inspect and, if necessary, repack the bearings and this is what I found where I expected a castle nut.
The wording says Dutton-Lainson. I found their web site, they are trailer parts suppliers, but I couldn't locate an image to match the one I attached to this posting. Wondering what I need to do to make sure the bearings are OK, and if I need to obtain a special applicator to squirt in some grease.
I plan on replacing the entire axle this year with something that has electric brakes. I don't need info on that aspect - there are hundreds of posts, I'm just mentioning it because the existing axle only has to last through the summer.
Thanks!
nigeleccleston is offline   Reply With Quote
Old 04-19-2019, 03:03 PM   #2
IllAnnoy
That looks like a dust cover of some sort. If so it just pops off revealing the spindle nut. just like an ordinary dust cover or a Bearing Buddy.
It appears to have a little bleeder button for use much like the pressure plate on a Bearing Buddy.
It clearly is not a Bearing Buddy.
That looks like an ordinary zerk, but go easy on the grease gun and probably press on that button ( maybe to release extra pressure.
I have never seen one like it so this response is largely speculation.
Old 04-19-2019, 03:46 PM   #3
Civilguy's Avatar
Puget Sound, WA
Dutton Lainson sells these as "Grease Keeper caps" in several sizes. The description for one says:
1 inch Grease Keeper dust caps with grease zirk and pressure relief valve. Protects wheel bearings from water and dirt with a positive hub seal. Supplies a reserve of lubrication and has built-in positive relief. Longer time between periodic repacking of bearings. Protects and extends bearing life. Zirk permits frequent greasing and relief valve eliminates excess pressure on grease seal. No complicated moving parts or gaskets that require costly maintenance and replacements. Easily installed in seconds, no need to remove hubs. A positive hub seal minimizes water entry when wheels are submerged. Zinc plated finish. Includes two protectors, each with a vinyl cover. Also fits 1-1/16 inch spindles.
https://www.dutton-lainson.com/prodd...php?prod=21842
Name:	Dutton Lainson Grease Keeper Cap lg21842.jpg
Since it sounds as though you have no brakes at present, you won't run the potential risk of having excess grease contaminate your brake shoes.
~ "This post is a natural product. Slight variations in spelling and grammar enhance its individual character and beauty and are in no way to be considered flaws or defects." ~
Old 04-19-2019, 03:57 PM   #4
I suggest you either repack the bearings or have them repacked. Part of the repacking process is bearing inspection. Just pumping grease into the bearings with inspection I believe is still looking for trouble. I have EZLub spindles and hubs but have never in almost 14 years have never put a grease gun to zirk fitting and probably never will. At 13 years the bearings needed replacing, the cost was pretty low and done by a Dexter axle shop. Actually a utility trailer shop that specialized in Dexter axles.
Old 04-19-2019, 04:15 PM   #5
Thanks everyone
I'll pry it off and repack.
Old 04-20-2019, 10:14 AM   #6
Trailer: !977 KingsleyGMC, 1968 Bailey Mikado
Nova Scotia
Mike, I have a good friend with a very comfie couch in your area that I really think you should visit. Would you like me to send his address ? LOL
Mike in NS
panhead_mike is offline   Reply With Quote
bearing buddy model number jkornfeld General Chat 14 11-11-2007 01:46 PM
BUDDY MACMASTER to perform at PEI Fiberglass with Class Meet KARL PROUDE Rallies, Get-togethers, Molded Meets (Archive) 0 05-01-2006 02:39 PM
Mr. Heater Buddy Portable Propane Heater Legacy Posts Problem Solving | Owners Helping Owners 16 08-03-2003 12:01 PM
Mr Buddy Propane Heater Legacy Posts Modifications, Alterations and Updates 12 02-08-2003 07:27 AM
Mr. Buddy vs. Black Cat Legacy Posts General Chat 1 09-15-2002 06:36 PM
