I installed an electric brake break-away switch on our
Casita last week. I used the existing hole that the main wiring cable goes through, and was careful to run the three break-away wires beside the cable, as opposed to above or below it, so the grommet clamp (or whatever it's called) wouldn't put direct pressure on it.
Should I be worried that the brake wires' insulation will eventually and activate the
brakes one day while I'm blithely cruising along the highway?
...lars
