Is this safe to use ?? - Page 2 - Fiberglass RV
Old 10-01-2013, 12:40 AM   #15
The straight side of the pin goes through the coupler of the sway device and the slots are positioned "below" the ball.
If I understood you correctly, that should solve the problem which you described above.
Floyd,
Yes, that is the way I assumed the pins to be inserted. I have also explored all other ways they could be inserted. None seem to allow them to remain un-distorted. I will replace the hitch pins with a closed end type.
Russ
Old 10-01-2013, 12:45 AM   #16
Originally Posted by vette_boy View Post
thanks brian , thanks for the info russ you answered most of my questions , do you leave the handle loose or do you tighten it so the bar can't move freely ?
I believe the device is intended to be run with the levered bolt tightened down all the way. The friction is dialed in with the other bolt that has no lever by using a wrench. That way you have a reference of optimum adjustment each time you hook up, and you wouldn't need a wrench each time to set friction. You will have to experiment to determine how much tightness works on your rig.
Russ
Old 10-01-2013, 09:21 PM   #17
Trailer: 17 foot boler
thanks Russ
vette_boy is offline   Reply With Quote
Is this safe ? Perry Mac Donald Care and Feeding of Molded Fiberglass Trailers 10 06-28-2010 02:56 PM
Safe stops Patricia Baxter Jokes, Stories & Tall Tales 0 07-19-2009 03:29 PM
How safe is this? Kevin K Care and Feeding of Molded Fiberglass Trailers 14 03-06-2008 09:13 PM
Need a Safe? Frederick L. Simson Modifications, Alterations and Updates 11 02-25-2007 12:04 PM
Is this safe ? tony suruda General Chat 0 12-31-1969 07:00 PM
