Its Back - J2807 New Common towing Standard - Fiberglass RV
Old 12-19-2014, 10:57 AM   #1
Glad to see the SAE-J2807 Standard for Tow Ratings is back on track!
Although this link/picture is a few years old now its a good visual as to what the test looks like.
Not surprised as Toyota did put the pressure on the big guys by being the only auto maker to advertise using it on all their 2014 models (trucks and SUV's).
Looks like in addition to Toyota, GM, Ford, Dodge will be using it on 2015 models and Nissan has said they will use it when they release updated models. With all of them using the new standard, its doubtful that any of the other auto makers will be able to get away with not using it in the very near feature. Can not seem to find anything official from Honda or Subaru as to whether or not they will be using it on their SUV's/cross overs or not when I googled the topic.
Nope the test is not perfect but its a start. Nice to know the auto makers are using the same method to determine their tow ratings. It might also help to ending the speculations here over the actual reasons behind auto manufacture set tow ratings.
Old 12-19-2014, 01:46 PM   #2
MC1
MC1's Avatar
I agree.
Generally speaking it's all about pick ups.
The tests have been published for years. It's good to know our car and mini can pass all the tests with ease.
The SAE folks want to see a 0 to 60MPH acceleration test in 30 to 40 secs depending on how the vehicle was equipped. That is, towing at 100% of the tow rating.
It is ironic our 150HP Mini Van could tow our 23' from 0 to 60 MPH in the 30 sec spec and our V6 G35 sedan can do it in less than 20 sec. So much for the tow rating on vehicles other than trucks.
Old 12-19-2014, 03:27 PM   #3
honda03842's Avatar
Name: Norm and Ginny
Regulations usually are written by the regulated, designed to help the regulated, tp preserve the status quo for them and excluding others.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 12-19-2014, 03:44 PM   #4
Raz
Raz's Avatar
Vermont
I used to see ads bragging how certain manufacturers trucks could pull 10,000 lbs. Now they pull 30,000 lbs. What changed? Raz
Old 12-19-2014, 04:14 PM   #5
P. Raz: I think they based it on "Truth first if possible" to stay ahead of the compentation then just lie about it if the proof wasn' t in the pudding.
Old 12-19-2014, 07:23 PM   #6
IllAnnoy
One concern is that this will lead to even bigger light trucks, which are already stupid big.
As for towing a 13ft fiberglass trailer... the standard is mostly irrelevant.
I'd like to see the comeback of small trucks and capable small SUVs.
To start a tangent... Rust has made a comeback not seen since the late sixties, probably due to the liquid deicer now being poured on the streets, so a lot of fairly new tow vehicles will be replaced sooner than expected which could speed up the implementation of whatever new standard is adopted.
Old 12-19-2014, 08:47 PM   #7
Although originally only intended for use for Light trucks - some of the manufactures have indicated they will be using it on their Heavy duty class trucks as well.
Toyota BTW in 2014 models used it on all their vehicles with tow ratings
Old 12-20-2014, 06:22 AM   #8
MC1
MC1's Avatar
For must of us on this forum who are towing very light to medium sized loads we need accurate specs and testing which would make up good numbers. The folks at SAE have not addressed this level of TV which is unfortunate.
Too often we see many on this and other forums spending their hard earned cash updating TV's. They expect more (based on vehicle size, weight, ratings, numbers, etc and end up being disappointed with towing performance, in one way or another.
Old 12-20-2014, 06:31 AM   #9
Borden's Avatar
Name: Borden and Carole
A couple of years back, was told I needed a F250 with dual rear wheels and a V8 to pull our boler trailer. That person thought a 13' boler required the same.
This comment started after I posted a picture of our car and trailer going down the road hooked up.
Our hitch was setup by a hitch expert; stops fine, handles well, we can go up Wiarton hill stop and start, 10th St or 6th St in Owen Sound same, reasonable wind control, drive all day at 90 kph.
Have been towing since the sixties trailers from 10' to 27'
Extra stopping distance to the next vehicle makes sense, reasonable turning speeds, after all safety first; they just want to give big rating to the trucks: but a lot of us pull small very light weight trailers for us it is more about the air we push than the weight.
Yes without trailer brakes we do need longer to stop have had to deal with that but it was not a problem. Always tow or drive with safety first in mind.
Those of us that pull with smaller tow vehicles will not win any indie races on a standing start with an incline on the many hills we encounter in our travels but still works fine; like the fuel savings.
Do believe keep it legal and keep it fun.
1978 Ontario made Boler
Old 12-20-2014, 09:00 AM   #10
SAE... Society of Automobile Engineers...
They don't write standards on how something made, or how it's designed. They write standards on how something is tested, or values are created. Many of the "testing" standards are applied across the whole transportation industry. I think it's about time the SAE created standards for testing to determine tow ratings for any vehicle.
Old 12-20-2014, 09:17 AM   #11
IllAnnoy
I don't think it is unfortunate at all, common sense, present law, and manufacturer's ratings are enough, along with SEMA and and the aftermarket.
We have enough valid information to make responsible choices for our selves, perhaps just not enough to make them for everyone else. Present DOT rules and limits are more than adequate for public safety.
I still say that the smartest and safest way for small and medium loads is to educate yourself and take responsibility for your own choices,knowing full well that no manufacturer is going to willingly take responsibility for any failure which involves so many variables.
"It's the driver's fault, no it's the tire's fault, no it's the other guy's fault, no it's the tow vehicle's fault, no it's trailer's fault, no it's the state's fault...no. it's GOD'S fault! ""ANYBODY'S FAULT BUT MINE!!""
Old 12-20-2014, 10:31 AM   #12
MC1
MC1's Avatar
Yup, know all about it Borden. About 15 years ago we headed down into Up State New York. Thinking it was Watkins Glen State Park. We were towing a 2,000 pop up with our 3,500 lb tow rated Nissan Mini Van. Got there late at night and got some sleep.
Woke up in the morning and looked around. Lots on different size small to mid size trailers and 85% of them were being pulled by 250 series pick ups. I really think it is a was a way of thinking/mindset, whatever, but it just seemed "different". Also note back then those 250's were fairly rough riding vehicles. Not something my butt would want to be in for a long vacation.
We were kinda ignored by the other campers. Not sure it was our choice of TV or just a not so friendly group. Anyway we ran across many, many friendly folks south of the border all of the other times we ventured that way.
Old 12-20-2014, 10:39 AM   #13
I suspect A 250 Dulley (Its a Macho Thing)
Old 12-20-2014, 10:50 AM   #14
MC1
MC1's Avatar
So true and many folks see it that way. A very well know towing specialist once wrote that....." because of the so many variables connected with the rig and set up that if he was a vehicle manufacturer, he would not apply a tow rating to any vehicle."
Makes a lot of sense. Leave the towing and rig set up to folks who are in the business of doing so.
Just another way of looking at it.
Common Tire Size Question Craig D. Thompson Towing, Hitching, Axles and Running Gear 2 04-10-2012 07:04 PM
Extremely common disease with no Known cure Tom U Jokes, Stories & Tall Tales 6 03-12-2011 09:28 PM
its not always the campground, its the people Gina D. General Chat 4 10-30-2010 02:21 AM
Is it common? Quint General Chat 10 11-16-2006 11:33 PM
