Jeep Renagade Towing? - Fiberglass RV
Old 09-16-2018, 08:31 AM   #1
Trailer: Scotsman
Hey folks! Just bought a 2015 Jeep Renegade Latitude, rated for approx 2000 lb towing capacity by the dealer. Anybody out there towing anything with a Jeep Renegade, and if so what? We are looking to possibly roll into the fiberglass RV world! Thanks! ....BillEllin
BillEllin is offline   Reply With Quote
Old 09-16-2018, 09:12 AM   #2
From what I've read, you need the 2.4L engine, 4x4 drivetrain, and a factory tow package to get that 2000 pound rating. Assuming all that...
A tow rating of 2000 pounds allows you to tow most 13' molded trailers, but no larger. A fully loaded Scamp deluxe front bath model with all the bells and whistles will push your limit. You will want a unit with brakes (not all have them) and 7-pin wiring with a brake controller on your vehicle.
If it were me, I'd stick with a more basic 13'er and keep the loaded weight well under 2000 pounds. The frontal area of a Scamp or similar, while fairly aerodynamic, is a lot more than the 20 sq. ft. used for tow testing in this weight class. If you can find a Hunter Compact Jr. or Trailswest Campster, which are both narrower and lower than a Scamp thanks to a pop-top design, even better.
Best wishes!
Old 09-16-2018, 01:42 PM   #3
jgilliam1955's Avatar
Trailer: Casita Liberty
Virginia
Tow in a jeep
Sorry you would be pressing your luck. Add you people and equipment you would take, I am pretty sure you would be at your limit or over. You needed to first decide what you wanted as a camper than get a tow vehicle. Since Jeeps are usually rated at the bottom for quality, I would be careful towing.
Been with my sweetheart since 1969
Burned by Snoozy, Now a Casita owner
We enjoy Whole Plant Base food
If I won the award for laziness, I would send somebody to pick it up for me.
jgilliam1955 is offline   Reply With Quote
Old 09-17-2018, 06:49 AM   #4
Late thought... Make sure you look up towing in your owner's manual and read everything it says. It often contains specific requirements and limitations beyond the simple weight rating. Don't rely on a dealer to know every detail for every vehicle. Things like frontal area, trailer brakes, required equipment, tongue weight- it's all in the fine print.
Jeep Wrangler, Short Wheelbase, for Towing John Hussey Towing, Hitching, Axles and Running Gear 26 01-02-2018 05:35 PM
Anyone towing with a Jeep Renagade yet? Arizona3313 Towing, Hitching, Axles and Running Gear 6 05-01-2016 12:32 PM
Towing with new Jeep Renagade? Arizona3313 Towing, Hitching, Axles and Running Gear 14 11-11-2015 04:00 PM
Towing with a Jeep CJ, YJ, TJ, LC FJ-40, LR SIII 80? jack smith General Chat 62 03-08-2007 10:25 PM
