Jeep TVs? - Page 3 - Fiberglass RV
Old 12-09-2010, 07:05 AM   #29
Yes I have two propane tanks and a front bath, but I can not understand why people think a front bath is heavy as all that is there is fiberglass and plastic as long as the black water tank is empty.
Bill K
Originally Posted by Christopher Phillips View Post
Bill K,
Do you have two propane tanks and a front bathroom?
I can lift my tongue up to place it on the ball and I am not that strong. I can't imagine mine weighing anywhere near that much.
What ever it weights it seems to be towing with good stability and no sway.
Old 12-09-2010, 08:39 AM   #30
DonDeutsch's Avatar
I don't know how much the individual parts weigh but 400 lbs of touge weight is excessive for a 2000 lb trailer. If anyone has a very high tounge weight for a 200lb trailer I would suggest checking the measurements ans cothen consider moving the trailer axel forward.
DonDeutsch is offline   Reply With Quote
Old 12-09-2010, 10:23 AM   #31
Don,
That 400 lbs figure came from Gina's stick built trailer and she did not say how big it was.
Bill K
Old 12-09-2010, 07:12 PM   #32
GuyB's Avatar
Trailer: 1979 Triple E Surfside
I pull a 14' EEE surfside.((1500 pounds dry) with our patriot and all is good but when loaded with gear and water I am pushing that tow limit rating at 2060 pounds. if your trailer is 1900 pounds dry no wonder your having issues on the hills.
I tow my 2010 16' Scamp with my 2007 Jeep Patriot. It tows great but when I get in the mountains I'm wishing I had something a little bigger. It tows it up but not fast. Otherwise I have no problems with braking and sway. I hauled it all the way form the factory in Backus MN to Albany NY with no issues. In fact, sometimes I forgot I was towing…
The scamp weighs somewhere around 1900 lbs.
The Jeep Patriot has a 2.4 L 4 cylinder engine with an all wheel drive CVT transmission. I average around 22-25 MPG while towing (about 28 mpg when not towing). The only thing I had to do was wire up a brake controller and a 7-pin tow harness. It has a tow capacity of 2000 lbs with the tow package and a hitch weight of 225 lbs.
For anyone that is looking for a good all-around TV that is good on gas and not too big I think the Patriot is the way to go for towing around our little FG RV’s as long as you are not in a very mountainous area
GuyB is offline   Reply With Quote
Old 12-09-2010, 07:27 PM   #33
Gina D.'s Avatar
West Coast USA
It was from my 17 foot Burro. My stick built one is not nearly as heavy.
The Burro had in front of the axles... most of the Kitchen, including the heavy fridge, a gaucho with storage beneath, g29 Battery, tackle for weight distribution (I had a single bar sideways mount) 2 propane tanks and a double hull.
The dry weight of the trailer was 2400 on the axles. Loaded it was 2820.
My stick built with NO fridge is 2400 on the axles, fully loaded. It isn't nearly as nice as the Burro, but it does tow a lot better.
Old 12-13-2010, 09:49 AM   #34
Name: William & Tina
Trailer: 1979 Boler
I haven't weighed the tongue on mine but it's a 17 foot boler with two tanks and front bath...and it's heavy.. takes two people to lift it onto the hitch.
B and TW is offline   Reply With Quote
Old 12-29-2010, 02:08 AM   #35
KevinWA's Avatar
Trailer: Trillium 4500 1978
still trying to post pic..hope it works aggggg!
KevinWA is offline   Reply With Quote
Old 12-29-2010, 02:09 AM   #36
KevinWA's Avatar
wow I got it!! yeah yeah yeah!!
Old 01-04-2011, 02:02 AM   #37
John Hussey's Avatar
Trailer: 2000 16 ft Casita Spirit Deluxe
Just wondering how many out there are towing with jeeps. Makes, models, problems, pics?
We are towing a 1978 trillium 4500 with a 2004 wrangler 6cyl 5 speed......not perfect, but the roof comes off!!
Good day to all,
Kevin
I'm towing a 16' Casita SD with a jeep Wrangler, 5 speed safari, 4 WD, straight 6 cylinder, 5 speed, and doing so with aplomb!
John Hussey is offline   Reply With Quote
Old 07-27-2011, 07:32 PM   #38
LLN
Trailer: Scamp 13 ft 2010
TV 2009 Wrangler 4dr
Tow with 4-dr 2009 Wrangler and managed the trip to the Scamp factory and back to Pennsylvania. Planning a longer journey to Montana this September. Hoping we can make the mountains with the 6-spd standard transmission. And the Goldens navigate.
LLN is offline   Reply With Quote
Old 07-28-2011, 06:53 PM   #39
KevinWA's Avatar
nice!!
Summary of smaller TVs? Bobbie Mayer Towing, Hitching, Axles and Running Gear 15 02-16-2010 07:21 PM
Does anyone tow with a Jeep TJ or YJ? Shelley Towing, Hitching, Axles and Running Gear 7 05-02-2008 07:52 PM
Jeep TJ 4cylinder/13'Boler tory mcdonald Classified Archives 6 07-07-2007 08:15 AM
boler jeep Legacy Posts Modifications, Alterations and Updates 32 05-29-2003 10:34 AM
