Jerking while towing - Fiberglass RV
Old 04-17-2009, 10:01 PM   #1
Roger C H's Avatar
Unhappy
I just completed a 200 mile round trip with my new 13' Trillium towed by a 2000 Subaru Outback rated at 2000#. The trip up was fine. I kept it about 50mph in an attempt to save gas and to build some experience with the rig.
However, on the trip back, the rig developed a 'jerking' motion fwd and back. It seemed to be caused by bumpy pavement, but not always. I also kept it at 50mph.
I thought of everything from bad clutch, loose axle on the Trill, misbalanced loading, etc.
Any experience with this motion out there?
Old 04-18-2009, 12:21 AM   #2
curtis c's Avatar
Trailer: 1994 Lite House
were you using cruise control? if so, that can do that.
curtis c is offline   Reply With Quote
Old 04-18-2009, 04:17 AM   #3
John Hussey's Avatar
Trailer: 2000 16 ft Casita Spirit Deluxe
"jerking' motion fwd and back"
Loose hitch ball?...Tighten nut quickly! (250 foot pounds torque)
Loose hitch in receiver?
John Hussey is offline   Reply With Quote
Old 04-18-2009, 05:54 AM   #4
pjanits's Avatar
Trailer: 17 ft 1986 Burro
Hitch ball too high? Trailer should be level or slightly down at hitch.
Old 04-18-2009, 09:07 AM   #5
Larry&Carrie's Avatar
Trailer: 1983 13 ft Scamp
Send a message via MSN to Larry&Carrie
Talking
Yeah, on I-5 south...... Where were you at when this occured, or was it all the time? Larry
Larry&Carrie is offline   Reply With Quote
Old 04-18-2009, 09:28 AM   #6
Phil Underwood's Avatar
Trailer: Bigfoot 21ft (25B21RB)
Odem,Texas
Send a message via AIM to Phil Underwood
was your fresh water tank full?
Phil & Denise Underwood
1997 Bigfoot 21 RB
2002 F-250
Phil Underwood is offline   Reply With Quote
Old 04-18-2009, 09:39 AM   #7
Raya's Avatar
There are some sections of I-95 in the Carolinas where I just go crazy from the trailer motion. It starts to cycle and even if I slow down to the minimum of 40mph it's still practically unbearable. It's an up/down sort of bobbing that really goes right through the whole rig.
On that same picee in a car (when not towing), you don't even feel it. I wondered if it was something to do with my rig, then one time caught sight of another truck and utility trailer on that stretch of road that was doing the exact same thing.
So it's possible it was the road and not your set-up.
Raya
Old 04-18-2009, 10:03 AM   #8
Steve L.'s Avatar
Trailer: 2003 Casita 16' SD
On certain concrete roads with my trailer and tow set up an uncomfortable motion as they cross the expansion strips. Usually speeding up or slowing down a skosh solves the problem for me.
Quando omni flunkus, moritati
Old 04-18-2009, 10:05 AM   #9
Trailer: 2012 Escape 19 / 2013 F-350 Crew Cab 4x4 Diesel!!!
There are sections of I-5 in Washington state that can produce a similar motion in my truck/trailer combo. It usually is an up and down motion as we go over the expansion joints in the concrete. Speed changes don't seem to have much effect. I just try to ignore it until it passes. BUT at times it's all I can do to tolerate it!!!!!!!
BC Paul is offline   Reply With Quote
Old 04-18-2009, 02:52 PM   #10
Raya's Avatar
Exactly, Paul. That's how it is for me too. Just an "up-down-up-down-up-down" as if you were a high-speed inchworm. Slowing down doesn't change it for me on that particular stretch either. Just makes any bobbing less likely to break something. I despise that stretch of road. But with just the car - I can hardly notice it.
Edited to add: In all of the 2800 miles I towed home with the Boler, I had none of that motion. Even at 65+ mph and/or in crosswinds. For me it's only on that one weird stretch of road. It could be trailer balance if you're NOT one one of those stretches.
Old 04-18-2009, 04:54 PM   #11
ddayton's Avatar
Trailer: 2007 Casita 17 ft Spirit Deluxe
Send a message via Yahoo to ddayton
Roger, et al
First confirm that you have adequate tongue weight. US experts seem to say 'at least 10 percent' of the gross weight of the trailer should be on the hitch. I agree more with those who suggest that 12 to 15 percent is a better target.
As you would expect that up and down jerking motion is amplified by the weight of the trailer in relation to the tow vehicle. It makes sense that a light tow vehicle would feel the effect of the movements from a heaver trailer.
The older concrete highways with tar strips almost caused me to stop traveling when towing my Scamp 19' 5vr. Then I starting using a Shocker Air Hitch and could forget the Scamp was there while driving over most any surface. Now that I tow a Casita 17' with the same tow vehicle, the Shocker is probably not necessary but since I have it I use it. It is a little pricey and probably not for everybody but if you really want to isolate the trailer from the tow vehicle it does work. (Disclaimer: I have no interest in Shocker other than as a satisfied customer.)
[attachment=23457:140_Ball...nstalled.
jpg]
Don
ddayton is offline   Reply With Quote
Old 04-18-2009, 07:07 PM   #12
Roger C H's Avatar
Unhappy
Thanks everyone for your input. It WAS on I-5 from Mt Vernon South. It did start on Hwy 20 from Deception Pass Park on Whidbey Island. After I exited the freeway, I purposely took a steep hill and the clutch pulled fine.
I was using the cruise. I will try not.
I thought of concrete expansion strips also, but the road was asphalt. But on second thought wasn't that asphalt laid over concrete? Also another possiblility.
We stopped at the Everett rest stop. I picked up the hitch (and car) and got no looseness or clicking like I would if something was not tight.
Fresh water tank was empty.
Hitch ball at height specified by Trillium. (16")
Again, thanks again for your contribution. I have several things to try if it happens again.
Old 04-18-2009, 07:29 PM   #13
curtis c's Avatar
hehe... it was most likely the cruise and heavy trailer light car combo. I'm 99% sure in your owners manual it says not to tow with the cruise on and also not in 5th gear for a manual. thats what it says for my 99 Toyota Tacoma and its rated at 5500 lbs towing and those 2 things will cause it to act funny when towing on my rig.
Old 04-18-2009, 08:29 PM   #14
Raya's Avatar
I think the "don't tow in overdrive" is strictly about not straining the transmission or (maybe) differential. I tow in overdrive sometimes (carefully, when not "asking anything" of the drivetrain), and there is no difference in how the trailer handles. Only in how I'm loading the transmission of my car.
Raya
New to towing :D JonE Towing, Hitching, Axles and Running Gear 3 07-13-2009 09:05 PM
Towing Jamie Towing, Hitching, Axles and Running Gear 20 08-15-2007 05:16 AM
Towing Legacy Posts Problem Solving | Owners Helping Owners 10 11-23-2002 07:42 PM
towing General Chat 0 12-31-1969 07:00 PM
