Larger tires/rims for my Bigfoot? - Fiberglass RV
Old 04-15-2008, 10:15 PM   #1
Trailer: 1994 Bigfoot 21 ft
I am thinking of getting new tires tomorrow (leaving for a long trip friday) for my 21 foot tandem axle Bigfoot. Currently have 14 inch rims and old trailer tires. I am thinking of getting some of these:
http://ricks-tire.com/product_info.php?pro...b264e1acf684e00
with, of course, new trailer 6 ply rubber to match (Titan tires). The guy at peters tirecraft said they should fit fine (i got my axles flipped last month for 5 inches of more travel) but they will stick out one inch more. As far as I can tell the one inch won't be an issue.
anyone see any issues with this?
thanks
Simon
Simon B Astin is offline   Reply With Quote
Old 04-15-2008, 10:54 PM   #2
Pete Dumbleton's Avatar
Umm, site said they only have two in stock...
Be sure that the wheels are suitable for the tire pressures (may be stamped inside wheels).
Spend a few bucks extra and get good HP metal valve stems.
You'll like the extra clearance and the towing might also be easier with less underside 'air dam' in front of trailer.
Old 04-15-2008, 11:48 PM   #3
Yeah, i am getting them locally here (in stock) - just found that for reference purposes.
thanks for the info though. will ask for the metal valve stems for sure.
Old 04-16-2008, 02:06 PM   #4
Trailer: Bigfoot (25B21FB) / 2002 Ford F-150 5.4L V8
Do you think that changing the wheel size will effect braking, since the brakes were chosen based on a different wheel size? Or maybe wheel size doesn't influence brake dynamics?
Mike D
Mike D is offline   Reply With Quote
Old 04-16-2008, 09:43 PM   #5
Yes, it could but I'm guessing you guys have 10" brakes, which cover a large range of wheel sizes (esp if there are brakes on both axles, as some jurisdictions require). I think most of my cars only had 8" brakes (I could be wrong about that; it's been a while since I had a car).
I've found trailer brakes to usually be more than enough to lock up the wheels (typical starting point for adjusting brake controller).
I'd be checking carefully, of course, if I was putting 16" wheels on axle with 7" brakes.
bigfoot, tires
Tow vehicle with rear tires larger than front tires? Cory Lewis Towing, Hitching, Axles and Running Gear 2 02-15-2010 11:33 PM
larger tires Lee Senn Towing, Hitching, Axles and Running Gear 1 04-29-2009 05:47 PM
tires n rims Tom Stewart Care and Feeding of Molded Fiberglass Trailers 45 11-06-2006 03:01 PM
Larger tires/rims for my Bigfoot? Simon B Astin Problem Solving | Owners Helping Owners 0 01-01-1970 12:00 AM
