Leading arm - Fiberglass RV
Old 02-10-2014, 02:36 PM   #1
Trailer: 1975 Boler
Leading arm
I want to replace my leading arm axle on my 75 Boler. After a few email exchanges with dexter I am told no one makes leading arm axles anymore. So I will go trailing. Right now I am trying to decipher his email of drawings. Wish me luck.
aznative is offline   Reply With Quote
Old 02-10-2014, 04:05 PM   #2
DaMScampers's Avatar
Luck!
DaMScampers is offline   Reply With Quote
Old 02-10-2014, 04:14 PM   #3
David Tilston's Avatar
Be advised, that I am no expert, but my understanding is that, a leading arm axle can be adapted from a trailing arm axle. Just reverse the brakes. That is install the left brake on the right arm, which will be the left arm when in the leading arm configuration. Visa versa for the right brake.
Old 02-10-2014, 05:18 PM   #4
Ah no, you flip the axle 180 degrees, then swap the brake hubs. If you REALLY want an axle built for an early Boler Gina, you can check with Paul and see if he'll ship one to the US: Fibreglass RV Parts, Repairs, and Service by Paul Neumeister
Scamp Axle - Leading vs Trailing RogerDat Towing, Hitching, Axles and Running Gear 70 07-01-2014 11:18 AM
Replacing an Axle - leading arm to trailing arm Roy in TO Modifications, Alterations and Updates 38 11-21-2010 01:00 AM
Replacing leading arm axles Andrew Gibbens Towing, Hitching, Axles and Running Gear 19 07-19-2008 06:48 PM
New Axle -- Leading or Trailing Arm? CliveAlive Towing, Hitching, Axles and Running Gear 3 01-26-2008 12:12 AM
New Axle -- Leading or Trailing Arm? CliveAlive General Chat 0 12-31-1969 07:00 PM
» Trailer Showcase
BigFoot
flyby
Eggcamper
Judy K
