Leading Arm or Trailing Arm - Page 4 - Fiberglass RV
Old 02-04-2016, 07:56 PM   #43
Bill Nolen's Avatar
Trailer: Had Scamp 13'.
Today i was told that my Scamp was ready to be picked up! Much faster service than I had expected.
The trailer company had installed 2-inch metal tubing between the axle and the frame. In addition, they had removed the hubs and inspected the spindles and bearings.
They found the spindles and bearings in good condition, but, replaced the old bearings and seals with new ones...plus new grease.
One interesting thing that they discovered was that there was no brakes installed on the axles. What makes this strange is the fact that there was wiring wrapped around the axle leading to both wheels, plus there was holes in the bottom of the trailer with the non-hooked up brake wires going inside the trailer. They thought it was possible that a older axle, with brakes, had been replaced, or that for some reason the brakes assys had been remover.
Of course, I'm leading towards thinking (and hoping) that a non-brake new axle had replaced the original axle that must have had brakes. But, it's something that will never be known, i guess.
The trailer towed just fine on the way home. However, I was unable to drive faster then 50 MPH.
Tomorrow if I have time I'll take a photo showing the tubes/fblocks. The cost was $210.00 for 3-hours labor and the new bearing and seals, which I thought was reasonable. Plus, I believe the trailer looks better being 2-inches higher.
Bill
Bill Nolen is offline   Reply With Quote
Old 02-05-2016, 01:06 PM   #44
Bill Nolen's Avatar
Photo of 2-inch welded tubing between axle and frame. As you can see the welds need painting, and the complete undercarriage needs cleaning.
Name:	<a title=Scamp new welded blocks 1.jpg Views: 9 Size: 236.8 KB ID: 92280" style="margin: 2px" />
Bill
Scamp Axle - Leading vs Trailing RogerDat Towing, Hitching, Axles and Running Gear 70 07-01-2014 11:18 AM
Replacing an Axle - leading arm to trailing arm Roy in TO Modifications, Alterations and Updates 38 11-21-2010 02:00 AM
Replacing leading arm axles Andrew Gibbens Towing, Hitching, Axles and Running Gear 19 07-19-2008 06:48 PM
New Axle -- Leading or Trailing Arm? CliveAlive Towing, Hitching, Axles and Running Gear 3 01-26-2008 01:12 AM
New Axle -- Leading or Trailing Arm? CliveAlive General Chat 0 01-01-1970 12:00 AM
