Leaf spring vs torsion axle: 1998 Scamp 13' - Page 2 - Fiberglass RV
Old 06-28-2014, 06:46 AM   #15
Originally Posted by katidesc13 View Post
I believe you are!! Why the 22 instead of the 45 you installed?
Because I (think) I finally figured out a good way to rework the discharge plumbing to one valve. But, it would require space between the trailer floor and the axle. Hence the spacer which using a 45 degree down doesn't need. Remember, I have a 16' trailer with a bathroom.
Old 06-29-2014, 09:56 AM   #16
Roy in TO's Avatar
Another thing I just remembered. The metric tires that replace the original 6.000 x 13 tires of early trailers have larger diameters. Today's tires will give you approximately another 1/2 to 1" more clearance.
Old 06-29-2014, 07:43 PM   #17
Idaho
Based on all this feedback I've come to a couple conclusions:
1) I'm leaning more towards sticking with the torsion axle. Although it's more expensive initially, it sounds like the install is a little less complicated because the dimensions and contact points are similar to what already exists on the trailer.
2) I will likely not need near as much clearance as I originally thought.
3) I have SOOOOO much research to do and I'm a little overwhelmed with the technical side of this project. Wishing I had someone a bit more experienced in this here to walk me through it. I've a very visual person, and trying to understand all the specifications and terms is really hard without visually SEEING what it is we're talking about. The Dexter resource library has been VERY helpful!!! Thanks for the suggestion!!
For now, I am having a friend look at the trailer to evaluate the quality of the current axle. If it's still in decent condition, I will probably just get new tires until I can invest the money in a new Dexter torsion axle and a little bigger tires. I'm still uncertain whether I should stick with the 22 1/2 degree down or go up to the 45 degree down axle (again, more research). I only have until September before I'm full-timing in it, so I need to make the most efficient, cost-effective decisions now.
Thanks for all your feedback!!
katidesc13 is offline   Reply With Quote
axle, scamp
Leaf spring vs torsion axle: 1998 Scamp 13' katidesc13 Problem Solving | Owners Helping Owners 6 06-27-2014 03:36 PM
Torsion Axle vs. Leaf Spring axle camper1887 Towing, Hitching, Axles and Running Gear 9 10-01-2012 05:32 AM
torsion springs or leaf springs Cat futrell Problem Solving | Owners Helping Owners 18 08-26-2012 08:12 AM
1975 Scamp 13 leaf spring conversion? pudgepuss Towing, Hitching, Axles and Running Gear 10 07-23-2011 09:39 PM
Leaf Spring/Axle replacement for a Scamp 13 DanMurphy Towing, Hitching, Axles and Running Gear 8 02-16-2008 01:56 PM
