Old 03-15-2009, 09:36 AM   #1
Taylor Kissinger's Avatar
Trailer: 19 ft Scamp (Egg Salad Annie)
On the Tacoma World Forum there is a lot of information about how to reduce bottoming out/ when towing. I test drove my Toy with the Scamp 5er on Friday it did not sag much at all and handled well on steep grades . But the leaf springs and shocks are new. I have Ordered some Timbren rubber shock helpers I want the great ride I have at present when empty. The Timbrens do not work until the rear Sags about an inch or so . They are rated at 2000lbs bolt on the rear shock stops, and are Warranted for life . These are a easy bolt on install .
Taylor Kissinger is offline   Reply With Quote
Old 03-15-2009, 03:51 PM   #2
Deb & Chuck's Avatar
Trailer: Fiberglass trailers
I have Roadmaster progressive suspension on my 2005 Tundra. It works very well no bottoming out, no body roll. It consists of a spring that hooks around the rear spring shackle to the center bolt on the truck spring. It can be adjusted for the load you may be hauling. My truck rides very good empty. I pull a bumper pull trailer and a 5th wheel trailer.
Chuck
Deb & Chuck
www.fiberglasstraveltrailersrv.com
Deb & Chuck is offline   Reply With Quote
Old 03-15-2009, 04:11 PM   #3
Chuck
Timbrens go were the rubber suspension stop goes . You remove 2 bolts and bolt the Timbren on. I will have to check out the Roadmasters
Timbrens rubber suspension Rozanne G Care and Feeding of Molded Fiberglass Trailers 8 01-12-2010 09:20 PM
Wag Bags Chester Taje General Chat 14 09-27-2009 12:33 PM
Truck Air Bags with.......17' Casita Wiliam H Towing, Hitching, Axles and Running Gear 4 08-11-2009 05:05 PM
Air bags vs. Helper springs on Chevy Astro Gary Little Towing, Hitching, Axles and Running Gear 8 09-21-2006 06:40 PM
Daddy's little helpers Legacy Posts General Chat 1 05-25-2003 07:22 PM
the next 365 days.
Our Communities
» More about our Communities
Automotive Communities
Marine Communities
Close [X]
