Long Road Trip with Subaru Forester and 13 Foot Burro - Fiberglass RV
Old 06-28-2015, 07:20 AM   #1
Trailer: Burro
New Mexico
I just came home from a wonderful trip from Albuquerque to Yellowstone National Park. My Burro 13 foot weighs less than 900 pounds. I was concerned about pulling it up over two mountain ranges without trailer brakes so I did a lot of research and discovered that as long as the loaded weight with all gear does not exceed about 1200 pounds, brakes are not needed.
My trailer followed and tracked perfectly and I never got up over 65MPH for safety. I took it slow down hills and steep grades and used my gears to slow down instead of the brakes when possible. My Forester pulled the trailer up the steepest grades with very little effort. I was very impressed. I averaged about about 21 MPG for the entire trip. I don't think I'll face steeper grades or more acute curves than I just faced and the Subaru handled it perfectly.
I still may put brakes on this unit because I think it's worth the cost and effort given that in an emergency braking situation it would be critical. I ran out of time before my trip to get this done. I did pull the wheels and my 1983 13 foot Burro does have the axel with the mounting plate with the four places to bolt on the new hubs and brakes.
For those of you wondering if it is possible to pull a 13 foot fiberglass RV with a 4 cylinder SUV, I am here to tell you...........YES YOU CAN! Subaru rates the Forester to pull 2000 pounds. I am well at HALF of that. The key is not to load the trailer with extra cargo weight. Less is more.
If any of you have any suggestions regarding good brake controllers I'm all ears. I am shopping for a good model now.
John Colangelo is offline   Reply With Quote
Old 06-28-2015, 08:01 AM   #2
honda03842's Avatar
Name: Norm and Ginny
I certainly believe a 4 cylinder can pull a small trailer. We towed a Scamp 16 or equivalent with a 4 cylinder Honda CRV for 7 years. However, though it's possible to tow a small trailer without trailer brakes, I suggest you add brakes to your trailer.
First it will reduce wear on your vehicle brakes but more importantly should you have a trailer problem like sway you can instantly stop it by 'manually' activating 'just' your brake controller.
As well the most common, though rare issue is the trailer coming off the ball, With trailer brakes and an inexpensive 'break-away switch' you can be protected against a runaway trailer.
Though I believe light trailers can be towed with an appropriate 4 cylinder, I also believe in trailer brakes.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 06-28-2015, 08:23 AM   #3
Be sure you get a proportional type.. From the reviews I have read, the Tekonsha line of controllers was a no-brainer. I choose this model because there was limited area to mount it in a Sienna Van (so many airbags!) and this one allows more flexibility than some cheaper Tekonsha models. Choose the model that has the features you need. etrailer is a good resource for you.. lots of good instruction on installs, etc.
It sure was a bear to install (at least to my satisfaction).. I hope you have a brake controller harness in your car, that makes it a lot easier.
Old 06-28-2015, 08:53 AM   #4
Raz
Raz's Avatar
Vermont
I set my 2012 Forester up to tow my 1700lb Trillium. I had no problem with the mountain grades but a big problem getting started. My car came with a hill holder clutch. On older Subaru's this feature was mechanical and could be disconnected but after 2010? It was programmed into the ABS. system. It made hill starts challenging and hard on the clutch. One outing and I went back to my pick up.
Here's my installation. Hope its useful. Raz
Subaru Forester Wired and Hitched
Old 06-28-2015, 10:06 AM   #5
Ask your dealer what it costs to install new rotors and pads on the Subaru. I think you'll find that adding brakes to the trailer is a bargain.
Old 06-28-2015, 11:03 AM   #6
WaltP's Avatar
Trailer: 2017 Escape 17B
SW Virginia
I towed a 13' Casita Patriot Deluxe with a 2000 Forester for about two years. I agree about installing brakes and I also added a transmission cooler. Otherwise it was an easy tow and a lot of fun.
Walt
Old 06-29-2015, 06:34 AM   #7
MC1
MC1's Avatar
Sounds like you are enjoying the Forester combo. FYI there is a guy on the Airstream forum towing a heavier 16' Bambi with a Forester. He is using a WDH. Works great.
RE brakes.... there is only a benefit by adding trailer brakes. Thinking you will like the mod.
Old 06-29-2015, 07:10 AM   #8
WaltP's Avatar
SW Virginia
Regrettably about three years ago, Subaru dropped the tow rating on the Forester from 2000 to 1500 lb, so the newer ones apparently are not as capable.
Walt
Old 06-29-2015, 07:16 AM   #9
frank_a's Avatar
Trailer: 2012 ParkLiner #006
We have the Tekonsha P3 and love it compared to earlier Tekonsha's we've had.
http://www.amazon.com/Tekonsha-90195...sha+prodigy+p3
Thanks for the post, and best of luck to you!
Frank
2012 ParkLiner #006
burro
Subaru Forester Wired and Hitched Raz Towing, Hitching, Axles and Running Gear 12 08-04-2012 06:10 PM
More Subaru Forester Towing Questions Michelle A Towing, Hitching, Axles and Running Gear 12 04-04-2009 10:18 PM
Subaru Forester Diesel? Bobbie Mayer General Chat 11 03-07-2009 07:23 PM
towing a 13' burro with a Subaru Forester Pamela H Towing, Hitching, Axles and Running Gear 5 07-23-2008 08:15 AM
Electric Brake Control for Subaru Forester Todd Sleeman Problem Solving | Owners Helping Owners 20 10-27-2007 10:08 PM
