Dually and Tire Failures
Actually none. The tire failures I am speaking of were due to tires being over age.
The well documented, December, 1991, recall for 1978-1985 Toyota motorhomes was due to axles failing (actually breaking off) at the bearing face and had no effect on the tires. And it wasn't a case of being Cheapo, the builders overloaded the Toyota chassis and , asToyota didn't even have a full floating
axle available until 1986 they went with aftermarket duals, a bad idea..... At the time of the recall, Toyota, although not at fault, provided a complete
axle upgrade kit, with a full floating
axle, 4 wheels and all parts needed to install in 1979-1985 chassis for the cost of shipping, about $85. About 90% of those affected have been updated over the years
