Low Clearance - Page 3 - Fiberglass RV
Old 11-09-2012, 08:16 PM   #29
Trailer: 2005 13 ft Scamp / 2004 Honda Odyssey
Hi Selina,
Your trailer looks great. I don't think the fabric is original, it was available when we bought our trailer in '05.
Did the previous owner remove the support on the dinette side of the kitchen? They add support to the roof and I would feel more comfortable with them being restored. You probably don't have to worry about snow load on the roof, but with weight in the cabinets and bouncing down the road, the trailer flexing.....
The original supports were black, they are now white. People have replaced the Scamp ones with ones they feel are more attractive.
Have fun in your new home.
Nancy
Nancy is offline   Reply With Quote
Old 11-09-2012, 08:21 PM   #30
IllAnnoy
I does look a little low, but a worn out dexter axle will be wearing the tires on the inside from progressively increasing negative camber and a developing tow out.
Early 13 Scamps used an up angle leading arm axle with a 1200# capacity, so it will sit lower than the later ones.
Below is a photo of a brand new circa 1978 Scamp 13 from the brochure, you can use it,along with other information to decide when it will be appropriate to replace the axle....
Old 11-09-2012, 10:10 PM   #31
Jared J's Avatar
Trailer: 1984 19' scamp
Kansas
Below is a photo of a brand new 1978 Scamp 13 from the brochure, you can use it,along with other information to decide when it will be appropriate to replace the axle....
oops, might want to ignore my post then, selina.
Good info Floyd!
Old 11-10-2012, 07:24 AM   #32
Trailer: 1973 Love Bug '13
Welcome Selina and congrats on your camper. This may not be relevant to the Scamp at all and Im sure there are many here who will know, we had a similar problem when we purchased a 1973 Love Bug in July. It was so low, but we did the bounce test and the torsion axle bounced and didn't hit bottom, we were able to use our axle but had it blocked. That is when a piece of metal is welded between the axle and the frame to lift the shell. We gained almost 4 inches.
Just a thought!
Cathy
Cat futrell is offline   Reply With Quote
Old 11-10-2012, 08:03 AM   #33
yyyyyguy's Avatar
Trailer: 17' Casita SD
Wisconsin
Originally Posted by Thomas G. View Post
Is this your house?
Wow, not quite that bad, how could anyone live there? Hope it isn't near me in the snowy,ICY north country
yyyyyguy is offline   Reply With Quote
Old 11-10-2012, 08:29 AM   #34
IllAnnoy
Is this your house?
That is amazing! I have a Ranger Edge and a Ford Escape.It would take a tentative approach from either of these just to test for angle of approach and departure. I can't imagine a regular car being able to enter that driveway, let alone scale it or park on it!
You would need a winch and wheels on the rear bumper to get a Scamp into that garage, that's if the door were high enough.
I can't see telling the kids to keep the tricycle in the driveway!
What is that parked on the dirt road in the background??
Old 11-10-2012, 08:33 AM   #35
AND, you definitely wouldn't consider driveway camping!
Old 11-10-2012, 08:58 AM   #36
Trailer: Bigfoot, Trillium, Scamp 5th Wheel
Spokane Wa. and Las Vegas, Nv.
"AND, you definitely wouldn't consider driveway camping!"
LOL! Let me see you level the fridge in that driveway.
Old 11-12-2012, 05:16 PM   #37
Selina187's Avatar
Trailer: 78 Scamp 13'
Originally Posted by Nancy View Post
Hi Selina,
Nancy
Thanks Nancy. Yes she removed the support to do some painting, but I still have it. It's the black one....we can't store it at home (no parking in LA) but we are planning on doing some work over the weekend, so I'll make sure we get that guy back on!
Selina187 is offline   Reply With Quote
Old 11-12-2012, 05:19 PM   #38
Selina187's Avatar
Thanks for the info Floyd! What a great old advertising pic!!!
Old 11-12-2012, 08:07 PM   #39
Hi Selina,
Your trailer looks great. I don't think the fabric is original, it was available when we bought our trailer in '05. Nancy
I suspect Nancy is correct - the original covers would have been the nice 70's gold plaid
Old 11-12-2012, 09:29 PM   #40
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
On the subject of the axle:
There was a lengthy discussion last year on this topic, and a member posted his very simple method of assessing a torsion axle's condition.
Here quoting from post #55 at Cost of axle
Originally Posted by Joe in MN View Post
Just a note about Scamp suspension - when replacing wheels on my new-to-me-last-fall 1988, the tires came off the ground almost the very moment that I touched the jack handle, so I'm assuming there's practically no spring left in the rubber suspension. This may be as good a way as any to assess the amount of life left in the suspension? Jack it up and see how long the tire stays on the ground as the frame rises?
He elaborates further on the next page:
Well, this is what I'm thinking, but I could easily be wrong - if the rubber is still springy, the weight of the trailer would be compressing the suspension somewhat all the time while sitting, and when the trailer was jacked up, the tires would stay on the ground for a bit until that "static compression" was taken out by jacking.
Think of it in reverse - if the trailer was suspended in the air and you gently set it down, the tires should rise up into the wheel wells a bit as the suspension compresses. This isn't happening in my case when I reverse the process, tires come off the ground IMMEDIATELY. There may in fact be some spring left between the resting position and the going-over-a-bump position (which is where you really want it), but I think my scenario means not a lot of springiness left anywhere.
I jack at the frame just ahead of the axle, which I believe is where Scamp recommends jacking. ($30 bottle jack from Northern Tool plus a Sears jack stand and chocks for safety - works really well for me so far.) I doubt that jacking up both wheels would tell you anything that one at a time wouldn't tell you, and it might stress the frame more - from what I've read, you have to watch how you jack Scamps up, as you can put stress in places where the frame isn't happy about it. On the frame, right next to the axle, preferably in front of it, and one side at a time is the best way, I think.
I think his is a good determinant for the question of whether or not to replace an axle.
That whole thread is pretty educational, by the way- a recommended read for anyone interested in the subject!
Francesca
Old 11-12-2012, 09:33 PM   #41
Jared J's Avatar
Kansas
That's exactly how the axle was in my scamp. I think it still had a little give, but the arms were way past where they should be, and when jacked, they also came off the ground immediately. New axle has some squat when weight is put on it, not much, but definitely more. It's also a 3500 pound axle vs. the 2000 pound one from before, though.
Ground clearance??? jime444 General Chat 16 05-04-2011 06:21 AM
Clearance J Joelson Problem Solving | Owners Helping Owners 4 07-29-2008 03:39 PM
Getting more clearance under your TT V'sGlassSleeper Problem Solving | Owners Helping Owners 9 08-30-2007 04:09 PM
Getting More Clearance rickster Care and Feeding of Molded Fiberglass Trailers 10 04-01-2006 06:53 PM
low road clearance Legacy Posts Problem Solving | Owners Helping Owners 3 07-21-2003 06:47 AM
