lowered hitch, tongue jack too low now - Page 4 - Fiberglass RV
Old 03-13-2014, 11:12 AM   #43
Trailer: Previously owned a Scamp 13'
New Hampshire
Hi, thanks, my jack is not an A Frame though, its a swing away type. I looked into replacing it with an A Frame but it would have hung down more than I wanted. There is really not much clearance under the trailer frame on my 13'er, only about 11".
Doghaus is offline   Reply With Quote
Old 03-13-2014, 11:39 AM   #44
Well you do have an A Frame tongue but sorry my error I gave you a link to the center mount jacks. You will find a number of different swing away jacks that will work at Swivel Jack Trailer - Etrailer.com - some are only 10" which would work but I see there are some rather cool looking Fulton's that appear to be pretty short below the bolt on.
Old 03-13-2014, 12:49 PM   #45
The swivel jack should be attached to the pivot by a BIG snap ring. That's how it is on our Uhaul which has a Tractor Supply jack mounted on the original pivot which is welded to the tongue. Sounds like your choice of a replacement jack will depend on the measurement from the pivot to the foot being shorter than your current jack. My guess is the welded on pivot will be the same. Remove snap ring CAREFULLY, lot of tension there and they like to fly off or pinch fingers even if you have the right tool, stick new jack onto pivot, reinstall snap ring, done!
mary and bob is online now   Reply With Quote
Old 03-13-2014, 01:05 PM   #46
Your right! - my Scamp is held by a large snap ring in the centre of the mounting plate welded to the tongue as well - the spring loaded locking mechanism going though another hole on the other corner of the mounting plate.
Old 03-13-2014, 01:18 PM   #47
New Hampshire
Super! Thank you. I think I get it but I'm sure hubby will really know what a snap ring is. I really can't wait to get the Scamp out and start in on this.
Old 03-13-2014, 03:22 PM   #48
rabbit's Avatar
Trailer: '98 BURRO 17WB
Delaware
Big 3" snap ring like that on the swivel jacks can be removed with a couple of common screwdrivers or a couple of pointed awls BUT snap ring pliers make it a breeze and you don't destroy the ring in the process. Buy the pliers or buy the time of someone who has a pair!
jack
Old 03-13-2014, 04:05 PM   #49
I was going to suggest fabricating a bracket to raise the pivot stub if it wasn't welded on, but most likely it is welded so a replacement jack would be the easiest solution.
Old 03-13-2014, 07:28 PM   #50
On my Scamp they have welded the mounting plate to the tongue.
Old 03-13-2014, 07:44 PM   #51
New Hampshire
Pro Series Round, Snap-Ring Swivel Jack - Weld On - Topwind - 10" Lift - 2,000 lbs Pro Series Trailer Jack PS1401140303
It doesn't fully show it, but the type of swivel jack that I am looking at comes with a separate mounting plate that is welded to the trailer frame. Then the Jack is attached to that plate with a "snap ring". This is the same type of jack I have on my trailer but in a taller version (15"). What I need to determine is if I can find a shorter jack (10") that will fit onto the plate for my existing jack that is already welded onto my frame. That would be an easy switch.
There is another type of jack that is bolted on, and yet another type that is called Pipe Mount. Learning a lot today. In our house I do the research and then hubby does the implementation. He is a genius at fixing and figuring out stuff hands on. I'm starting to bring up the subject of adding trailer brakes...
Old 03-13-2014, 07:52 PM   #52
New Hampshire
Dimensions of Mounting Plate on Pro Series Weld-On Snap Ring Swivel Jack # PS1401140303 | etrailer.com
guess this is what I'll be comparing measurements to!
Thanks everyone for all the advice.
Old 03-13-2014, 08:25 PM   #53
Originally Posted by Doghaus View Post
It doesn't fully show it, but the type of swivel jack that I am looking at comes with a separate mounting plate that is welded to the trailer frame. Then the Jack is attached to that plate with a "snap ring". This is the same type of jack I have on my trailer but in a taller version (15"). What I need to determine is if I can find a shorter jack (10") that will fit onto the plate for my existing jack that is already welded onto my frame. .
Is this Fulton Weld On Sidewind with 10" Lift not mounted the same as the one on your Scamp now?
Old 03-13-2014, 08:30 PM   #54
When I installed my tongue box the crank handle would hit the box. I ground off the welds that held the jack tube to the bracket that goes on the pivot, turned the tube about 45 degrees, and welded it back. I could have, and probably should have, raised it up a little. There's an option for you.
Old 03-14-2014, 05:28 AM   #55
New Hampshire
Hi Carol,Yes, that is mounted the same way.
Mary Bob, I'm trying to get away with NOT welding, that is one skill we don't have. Actually I do know how to weld, which is a story in itself, but I'm not good enough at it to actually do it on something that matters.
I have a topwind jack now with no wheel on it, and I'll probably stick with that unless I determine that a sidewind will work. I've learned how to avoid hitting the propane tank on the back part of the swing with the topwind, but I do still hit it from time to time. Somehow I think there is something else that will interfere with the sidewind. Can't wait to get the Scamp out of storage now!
Old 03-14-2014, 09:10 AM   #56
You probable already realize this but while looking through your chooses of what to replace your current one with that you do want to look at ones that say weld on, even though you do not wish to or need to actually weld it. In most cases the weld on is referring to the mounting plate you already have welded onto the tongue of your trailer.
Tongue jack modification cpaharley2008 Towing, Hitching, Axles and Running Gear 18 04-22-2018 06:49 AM
Tongue Jack Replacement? Parker Buckley Problem Solving | Owners Helping Owners 8 12-03-2007 08:06 PM
A Frame tongue jack Timmy G Problem Solving | Owners Helping Owners 5 11-25-2007 10:31 AM
Tongue Jack Parker Buckley Problem Solving | Owners Helping Owners 16 11-14-2007 08:06 PM
Power tongue jack Legacy Posts Modifications, Alterations and Updates 20 07-20-2003 02:42 PM
