lowered hitch, tongue jack too low now - Page 5 - Fiberglass RV
Old 03-23-2014, 09:12 PM   #57
Nevada
I think this was previously mentioned, but if not: a jack stand works for me. If the swing jack is too tall to swing down, I use the jack stand to un-hitch the trailer. I prefer the stability of the stand to the wheel on my swing jack as well. Adjustments can be made with the wheels chocked either by hand (lifting the tounge while somebody lowers the jack stand) or by placing a block of wood under the tongue, lowering the stand, and carefully tapping out the block with a mallet.
solarscamp13 is offline   Reply With Quote
Old 03-23-2014, 09:41 PM   #58
sounds like this involves lifting, but for me with 3 bad discs in my back that is not possible. I prefer letting the mechanical devices do the work!
Old 05-06-2014, 06:25 PM   #59
Trailer: Previously owned a Scamp 13'
New Hampshire
new tongue jack installed!! Thanks everyone!
Hi, just a followup: I got a slightly shorter tongue jack from etrailer and we installed it tonight. It will give me almost an inch more clearance for swinging down the jack. I also bought the 1" highrise hitch ball which we will put on probably tomorrow. This will give me plenty of clearance, I shouldn't have to use the scissors jack anymore, and the camper should now ride level if my calculations are correct. The jack install was very simple, we just removed the snap ring from the old and new jacks, cleaned the rust off of the mounting plate, swapped the jacks, and reinstalled the snap ring. The only problem we had was that the snap ring tool was not quite large enough for the extra large snap ring on the jack, but my hubby figured it out somehow.
Thanks everyone!
Doghaus is offline   Reply With Quote
Old 05-06-2014, 07:07 PM   #60
They are quite a snap ring aren't they !!!
Tongue jack modification cpaharley2008 Towing, Hitching, Axles and Running Gear 18 04-22-2018 06:49 AM
Tongue Jack Replacement? Parker Buckley Problem Solving | Owners Helping Owners 8 12-03-2007 08:06 PM
A Frame tongue jack Timmy G Problem Solving | Owners Helping Owners 5 11-25-2007 10:31 AM
Tongue Jack Parker Buckley Problem Solving | Owners Helping Owners 16 11-14-2007 08:06 PM
Power tongue jack Legacy Posts Modifications, Alterations and Updates 20 07-20-2003 02:42 PM
