Manitoba insurance requires brakes and weight distrib hitch? - Fiberglass RV
Old 08-16-2009, 10:45 AM   #1
Any MB members out there who can confirm this? Looked at a trailer that had electric brakes but they were disconnected. The owner doesn't use a special hitch or the brakes, big diesel truck and a 14 ft trailer. But someone from the local RV place said you have to have both if the weight is 2000 lbs for insurance reasons. This seems like overkill... but can't seem to get an answer on whether it's recommended or required. In our province there is only one insurer operates as a crown corp, so there is no other choice.
SherLynn is offline   Reply With Quote
Old 08-16-2009, 09:28 PM   #2
kevin61's Avatar
Trailer: Two 13 ft Bolers and one 17 ft Boler
If it has servicable brakes then the wiring is relatively simple. You will need a brake controller in your vehicle.
See my posting #3 at
http://www.fiberglassrv.com/board/in...howtopic=36824
kevin61 is offline   Reply With Quote
Old 08-17-2009, 01:40 PM   #3
Roy in TO's Avatar
Does the trailer your looking at exceed 2000 Lbs?
Some info is here:
http://www.rvforum.net/index2.php?option=c...df=1&id=155
and from the horses mouth so to speak
http://www.mpi.mb.ca/english/newsroo...er/towing.html
edited to add second link
brakes, weighing, weight
Manitoba Boler requires axle replacement. Recommended Shops? Tom and Colleen Towing, Hitching, Axles and Running Gear 7 10-08-2014 08:31 AM
Weight Distribution Hitch Parker Buckley Towing, Hitching, Axles and Running Gear 4 09-17-2009 09:03 PM
Looking for a Weight Distribution Hitch ROIDON L Towing, Hitching, Axles and Running Gear 2 07-18-2009 10:39 AM
weight distributing hitch Legacy Posts Towing, Hitching, Axles and Running Gear 18 02-26-2003 05:36 PM
Weight Dist Hitch - I Wouldn't. Legacy Posts Towing, Hitching, Axles and Running Gear 3 11-03-2002 02:40 PM
