Michelin LT Tire Recall - Fiberglass RV
Old 07-12-2013, 01:27 PM   #1
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
NEW RECALL Michelin Light truck replacement Tires
For those of you running Michelins on anything:
As posted today on its Facebook page, Michelin has announced a voluntary safety recall of certain of its "light truck replacement tires".
Specifics can be found at this Michelin link.
Francesca
Old 07-12-2013, 02:01 PM   #2
Brian B-P's Avatar
Michelin Recall is of P-Metric Tires
Thanks for the heads-up, Francesca, but none of the recalled tires are of the LT type; they are all P-metric. The title of the announcement includes the words "light truck" because these tires in these sizes are typically used on light trucks and SUVs. The term "LT" has a specific meaning in tires (referring to a specific Tire & Rim Association classification), beyond simply being an acronym for "light truck", and these tires do not fit this meaning.
Old 07-12-2013, 02:12 PM   #3
Thanks, Brian
Noted and fixed both title and post on edit.
Francesca
Old 07-14-2013, 08:42 PM   #4
Night Sailor's Avatar
Connecticut
These are all 18", 19", and 20" tires. It your TV is a smaller size you are not effected by the recall.
light, tires
Hercules All Trac A/T tire recall Roy in TO Towing, Hitching, Axles and Running Gear 0 06-28-2013 09:15 AM
anyone using Michelin MS2 tires? arlon Towing, Hitching, Axles and Running Gear 6 05-16-2013 07:52 PM
New Michelin tires cpaharley2008 Towing, Hitching, Axles and Running Gear 17 02-20-2012 05:10 PM
SAFETY Recall of Metal Tire Valve Stems bobinyelm General Chat 2 09-11-2009 06:53 PM
Tire Valve Recall Darwin Maring Towing, Hitching, Axles and Running Gear 13 08-16-2008 06:41 AM
