need axle replaced - Fiberglass RV
Old 08-12-2008, 10:59 AM   #1
hi all,
i have a 1979 trillium jubilee. the axle has an injected rubber something or other that i have been told cannot be replaced. how big a deal is it to replace the axle? has anybody had any experience with this?
thanks vh crowell
verna crowell is offline   Reply With Quote
Old 08-12-2008, 01:08 PM   #2
Trailer: Fiber Stream
Unhappy
Hi. Welcome to the site.
In the upper right hand corner, next to the "Help" button, is the "Search" button. When you click on it, a small window will open. Go to the line that says "More Options" and click on that.
In the new window, Type replace + axle into the box, and click on "enter."
That will bring up one post is each thread with those keywords. Clicking on the Title will display that whole thread.
Sorry if this is short, but I'm writing this on my Lunch Break at work, and my Boss is comming...
Old 08-12-2008, 01:18 PM   #3
Booker B.'s Avatar
Trailer: 1976 Trillium 13 ft
Hi Verna,
Do you know if you have a.) electric brakes and b.) if so do you use them?
Generally the Trillium came with Dexter axles so I did a search on +trillium +dexter
I have a few good results including this one:
Trillium Axle Replacement, Installed Dexter 3000# axle w/10" elec brakes
Old 08-12-2008, 02:02 PM   #4
If it is Bolted on, it is somewhat easy.
If it is welded on then you have to have it removed and unless you are a welder, you will have to take it to a welder that is good with a torch and then after the removal I recommend that you have it installed so it will be bolted on.
Axle Source www.harborfreight.com
Old 08-14-2008, 07:46 PM   #5
ok...good information..thanks a lot for the help. verna crowell
axle
replaced front bunk Marty Smiltneek Modifications, Alterations and Updates 11 06-30-2009 01:19 PM
For those that have replaced the interior covering... Stacy Crotser Problem Solving | Owners Helping Owners 30 05-16-2009 07:54 PM
Replaced the big microwave ronsmith100 Modifications, Alterations and Updates 3 05-08-2009 10:39 AM
Replaced my icebox with.... efawcett Modifications, Alterations and Updates 4 11-18-2007 09:52 PM
Can Icebox be replaced with Refrigerator? bobby & linda Modifications, Alterations and Updates 16 05-30-2006 06:22 PM
