09-27-2009, 05:15 PM
I just got a P3 and wired to the Tundra for a trip to Florida yesterday.
The Manual I found for it say to adjust the power buttons to 6 to start testing and turn up or down as needed to get brake lock-up and adjust from there.
My question is....When I press the power buttons all I see on the display s the Voltage expessed in volts but I never see the numerical adjustment as I only get the voltage reading?
Any ideas?
The manual was not in the box with the control and I am going from what I found on the net.
Ed
09-27-2009, 08:51 PM
Trailer: 1991 Scamp 16 ft
Just press the up arrow until it gets to 6.0 to start with and you drive it and test it and then keep adjusting it from that point based on your results. The voltage reading is what you are adjusting. At rest, it will always be zero and you are adjusting for the "maximum" voltage that is necessary to stop your trailer. When you put the manual lever all the way to the left, it will give you your maximum voltage that is being applied. Hope that helps.
"The babbling that I brook." - Pink Floyd
1991 Scamp 16'
09-27-2009, 09:00 PM
FWIW
When I got my new Scamp I could not get the P3 to make the brakes work like the manual said.
I got it the best I could and started driving. Later that day I tried the manual switch and locked up the brakes.
I then readjusted the controller and they worked fine since then.
Bill K
09-28-2009, 03:36 AM
What I mean is that I never get to adjust the numbers as yo suggest.All I see when I adjust the power buttons is a Voltage reading,it never shows anything else while adjusting?
I certainly read exactly what you suggest in the manual but again mine only displays the voltage when I press the buttons.
Do I just misunderstand what I am reading?
Am I supposed to see the Voltage only while adjusting and then only see the other numbers while actualy applying the brakes?
Also it does seem to work and I am certainly getting trailer brake action from it,I just can not understand the adjustment without seeing anything but the Voltage?
Thanks
Ed
09-28-2009, 07:10 AM
Trailer: 1981 Trillium 5500
from the manual:
Once the control has been securely mounted, it is necessary to set the power needed to stop the trailer during a braking event.
1. Connect trailer to tow vehicle.
2. With engine running set power (with Power Buttons) to indicate 6.0
3. Drive tow vehicle and trailer on a dry level paved surface at 25 mph and fully apply Manual Knob.
✓ If trailer brakes lock up:
❑ Turn power down using Power Buttons.
✓ If braking was not sufficient:
❑ Turn power up using Power Buttons.
4. Repeat Step (3) until power has been set to a point just below wheel lock up or at a sufficient force as to achieve maximum braking power.
5. Using the brake pedal, make a few low speed stops to check the power setting. Trailer braking is
initiated and terminated via the stoplight switch.
When the brake pedal is released, trailer braking will cease.
Boost Setting
The boost button was designed to allow a more aggressive setting for your trailer brakes and is available in three levels - B1, B2, B3.
Each incremental boost setting increases the sensitivity of the P3’s inertial sensor,
enhancing the participation of the trailer brakes during a braking event.
09-28-2009, 10:44 AM
from the manual:
Boost Setting
Thanks for the quote,I know what it says but I am telling you that I do not see the readout it says to follow.
I see only a voltage readout expressed in volts I never see just numbers to adjust to 6 as it says.
It makes it impossible to begin the setup process when I do not have the ability to do the first step?
Thanks
Ed
09-28-2009, 12:09 PM
My question is....When I press the power buttons all I see on the display is the [b]Voltage expressed in volts but I never see the numerical adjustment as I only get the [b]voltage reading?
Ed:
Numerical Adjustment [b]= Voltage Reading
Range is 0.0 to 13 [b]volts. ( above 9.9 the reading is in whole volts due to having only 2 digits in the readout) This is an indication of voltage output to the electric brakes. What you are doing with this adjustment is setting the Output Voltage to a mid-range reading of [b]6.0 volts DC as a starting point. The controller works by varying the output voltage to the brakes in proportion to the pressure you apply to your brake pedal. Slowing from 60 mph to 50 mph using the brakes may only send 1.5 or 2.1 volts to the brake magnets. A panic stop standing on the brake pedal with all your effort sends 12 or 13 volts to the brake magnet.
09-28-2009, 01:04 PM
If it will not work either call or e-mail the company. I understand they are very easy to work with.
Bill K
Thanks
Ed
09-28-2009, 10:28 PM
Ed,
Connect your trailer and wiring,
Start your vehicle and leave it in park (or if standard neutral with parking brake on)
The P3 should run through a quick self test
Then push either the up or down arrow to the left of the screen a few times
the numerical values should be your voltage readings as others have indicated and should increase or decrease as you press the appropriate arrow.
post what you see when you push the arrows
09-29-2009, 03:24 AM
Fred
If what you say is the case then that does make some sense.
The thing is that the look of the numbers(font,etc.)is completely different when displaying the voltage and the output numbers they show in the manual.
Also why don't they just say adjust the output voltage to 6 volts to begin the setup which would make it simple to understand?
Roy
Like I keep saying,it does not appear to be the same reading when I start to adjust.It goes from display of output on some random scale before I push the buttons and it is the same scale as when braking to immediately show voltage once I push a button.
I am working here out of town so I can not try this right now but I will call the company and ask them too.Maybe I just need to reset the thing and see if the display changes?
Thanks
Ed
09-29-2009, 10:39 AM
Mine is less than six months old so we should have the same features. I was getting ready to take my trailer back to storage after a trip to South Dakota and shot this video while I was at it. I hope it helps clear things up a bit. Excuse my discolored thumb nail. Darn miracle ladders!
http://picasaweb.google.com/lh/photo/R_-Gt...feat=directlink
1991 Scamp 16'
10-05-2009, 06:01 PM
Sorry Ed, I was thinking of my prodigy, not the p3, now I know why you're numbers were different.
Joe
10-06-2009, 07:31 PM
Ed, what ever happened with this? Did you get it figured out? Was the unit defective. Inquiring minds want to know!
1991 Scamp 16'
