New Axle on My Trillium - Fiberglass RV
Old 01-15-2012, 06:34 PM   #1
Paul Richter's Avatar
Trailer: Trillium 1971 13 ft
Hi there, folks, I'm in the prcess of getting quotes to get my axle changed out any thing that you guys can think I should ask?? I'm planning on getting brakes installed on it as well. used:
Paul "The Nascar Rig"
https://community.webshots.com/user/p...host=community
Paul Richter is offline   Reply With Quote
Old 01-15-2012, 06:37 PM   #2
Bolted on to welded brackets, rather than welded to the frame...
Old 01-15-2012, 06:46 PM   #3
Thomas G.'s Avatar
What kind of axle? I think some of them have replaceable spindles so that if you damage a spindle you don't need to replace the whole axle. That seems like an advantage. Definitely go with brakes.
Spindle,2200# Torsion Replacement / Ec- 80047 | Spindles | Tie Down Eng | TrailerPartsDepot.com
Old 01-15-2012, 08:23 PM   #4
Spanke's Avatar
Trailer: 1978 Trillium 1300
Cumberland, Indiana
Your Trillium has a torque-flex type axle on it. If you want brakes, get electric ones. This also means that you will need a brake controller in the TV if you don't have one already. On a Dexter axle the E-Z Lube is a nice feature. Also, get the brackets that welds to the frame and allows the new axle to bolt on.
This first link lists the original specs for your axle. This is pretty much all the info you need to get one like the original.
http://www.fiberglassrv.com/forums/f...xle-25490.html
This second link is where I bought mine. Good prices, nice to work with.
#9 Torflex 1000-2200 LB at Humphreys Hitch and Trailer Parts
I would purchase a new one over a used one, you already have a used one!
Good luck on your project.
Spanke
Trilliums Rock!
Old 01-15-2012, 08:25 PM   #5
WildBirder's Avatar
Find out if the new axle will change the overall height of the vehicle and wether that will effect your storage needs.
WildBirder is offline   Reply With Quote
Old 01-16-2012, 12:06 PM   #6
David Tilston's Avatar
Brakes are a must. Capacity should be considered as well. My Trillium 4500 came with a 2000lb axle. New Trillium 1500 (metric 4500) are specified as 1700lb. This would have left 300lb for gear, food, luggage.... Not enough. The frame is built to handle more. I had my axle and coupler changed to carry more stuff. I have 5 kids.
axle, trillium
Trillium Axle Don N Towing, Hitching, Axles and Running Gear 16 01-24-2009 06:34 AM
Trillium new axle Bogdan D Towing, Hitching, Axles and Running Gear 3 06-14-2008 03:19 PM
Trillium axle replacement Bogdan D Towing, Hitching, Axles and Running Gear 8 04-20-2008 08:31 PM
Trillium Axle Replacement Joseph Olajos Towing, Hitching, Axles and Running Gear 5 06-01-2007 12:59 PM
Trillium Axle JohnWalker Towing, Hitching, Axles and Running Gear 2 05-22-2006 01:11 PM
» Trailer Showcase
Hilton
Rolf Dobelli
ET
Al Bear
