New axle quick question about the brakes - Fiberglass RV
Old 05-08-2014, 12:40 PM   #1
Trailer: 1975 Boler
Time to finally finish up the wiring. Got my correct axle finally. So I noticed there are 2 wires for the brakes its not marked which is positive and which is negative. So I assume I just pick one to be positive and run it up to my 7 pin plug? Also Ground should I run it to my trailer frame or up to the plug as well? I'm thinking the plug as well.
aznative is offline   Reply With Quote
Old 05-08-2014, 12:50 PM   #2
My ground is connected to the frame on both sides and also tied together so should 1 ground go bad, it will get it from the other side.
The hot wires come together under the camper and one wire goes up to the connector.
Old 05-08-2014, 01:14 PM   #3
David Tilston's Avatar
The wire you run from you plug to the brakes is typically blue. I would go #12. That is over kill, but hey, it's your brakes. The other wire is ground. I never use the trailer frame for ground, (though it is connected to ground). I always run a separate white wire for that, tied to the trailer frame. Right back to the trailer plug.
Here is what E Trailer has to say about wiring.
http://www.etrailer.com/faq-wiring.aspx
Old 05-08-2014, 01:26 PM   #4
frank_a's Avatar
Trailer: 2012 ParkLiner #006
Trailer Wiring Diagrams | etrailer.com
Everything David says here is the way I do it too. Grounds are critical, things don't work well (or work at all) if you scrimp on the ground.
Frank
2012 ParkLiner #006
2013 4wd Escape 2L Ecoboost with 3500# tow package
Old 05-08-2014, 01:31 PM   #5
Did you have or plan to install a breakaway switch? this must be installed in the positive line used on the brake coil.
Old 05-08-2014, 01:43 PM   #6
Trailer: 1975 Boler
I am using 10 gauge for all wiring.
I did not think of a breakaway switch. Hmm wonder if checkers has any.
Old 05-08-2014, 01:47 PM   #7
frank_a's Avatar
I wouldn't doubt Checkers has them, but might have to order one in.
Breakaway Kit Installation for Single and Dual Brake Axle Trailers | etrailer.com
2012 ParkLiner #006
Old 05-09-2014, 07:49 PM   #8
If you are going to do the work, buy one that won't drag on the ground or require zip ties. Do it right the first time! 4' Zip Breakaway Cable & Switch
Old 05-09-2014, 08:52 PM   #9
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
According to the Dexter brake-equipped axle instructions at this E-trailer link, your presumption is correct: the magnets don't care which wire you choose to be hot/not.
My advice per ground would be to use the main trailer ground, and with the same gauge ground wire used in the rest of the rig.
axle, brakes
New Axle w/brakes for 13 ft Scamp in SF Bay Area KenTorke Classified Archives 0 05-30-2008 09:43 PM
Quick stop question Pat M Care and Feeding of Molded Fiberglass Trailers 7 05-25-2008 04:20 PM
A Quick LED light question Bonnie Problem Solving | Owners Helping Owners 3 11-23-2007 10:10 AM
brakes or no brakes Penney H. & Mike E. Towing, Hitching, Axles and Running Gear 17 08-13-2007 02:35 PM
Quick question for you Oregonians and others Joy A Camping, Campout Reports 7 05-01-2007 07:11 PM
