New Fiber Stream Tires - Fiberglass RV
Old 04-18-2016, 05:04 PM   #1
Trailer: Fiber Stream
Maryland
Anybody switch to a ST145R12, LT145R12, or 145R12 commercial tire to replace the 5.80 x 12 ?? Need to do ASAP!
Thanks!
Dave in Baltimore MD
JD1994 is offline   Reply With Quote
Old 04-18-2016, 05:21 PM   #2
14" wheels & tires won't fit unless you raise the trailer high enough to move the axles farther apart.
13" wheels and tires j-u-s-t fit; an owner in Oregon switched to them years ago... but that brings the tires within 1-1/2 inches of each other at their center-line... leaving no room for any commercially made chocking system that goes between the tires, and brings the tire very close to the edge of the wheel well.
Old 04-18-2016, 05:44 PM   #3
Exclamation
Oops! mea culpa.
I misread the sizes you stated.
I have not seen those tires you mentioned available here in California. I can only get 4.80 x 12 or 5.30 x 12
Old 04-18-2016, 06:00 PM   #4
Trailer: Bigfoot B-17 CB
The 145 refers to the width of the tire at its widest point, when it is mounted on the rim and inflated. Width is measured in millimeters.
145 MM = 5.704 inches. A 580 X 12 is pretty darn close. Should work fine.
fiber stream, tires
New purchase of Fiber Stream slbran Care and Feeding of Molded Fiberglass Trailers 6 07-09-2013 08:26 AM
Pics of the "New" Fiber Stream flyby Hi, I am.... 16 04-06-2012 06:49 PM
New Springs for my 16' Fiber Stream Steve Lang Towing, Hitching, Axles and Running Gear 3 06-11-2008 05:35 PM
New Fiber Stream owners! C Rogers General Chat 5 04-17-2007 06:33 AM
New (old) Fiber Stream in town Ron Wrighton General Chat 4 08-08-2006 08:50 AM
