New Shocks? - Fiberglass RV
Old 12-06-2013, 11:13 AM   #1
Trailer: ParkLiner
Virginia
New Shocks?
Hopefully I will be picking up my new Parkliner in a couple of months. I plan on towing with a 1996 Chevy Blazer.
I am not very mechanically inclined, so thought it would be good to do some maintenance on the Blazer to learn a little bit, so if necessary I can do emergency repairs. I just took the old, dented bmperer off and am waiting for the junk yard to call me and say they have 1 ready for me to pick up.
Should I replace the rear shocks? If so, what type would you recommend?
What other maintenance/upgrades should I do before towing?
Huck is offline   Reply With Quote
Old 12-06-2013, 12:56 PM   #2
With a high mileage tug I personally would check The rear brakes, fronts are usually better maintained since they do most of the stopping in daily operation, lube/ check the drive shaft, by 100,000 miles the u-joints have done their time. This applies to sealed rear axle bearings too. When these items fail on the highway you will hear a grumbly noise and then a disasterious bang, not much interval between the 2. Raise the rear tire pressure for the load incountered when you tow. If your rear tires are not showing any weird wear patterns the shocks are probably OK. Warn shocks usually show up when the cars is lightly loaded instead of heavily loaded. Any loose or squirly steering issues will be worse with the trailer load on the back. If you dont feel comfortable with your Blazer to hop in and drive cross country it would probably be prudent to have a good established mechanic put it on the rack and give it the once over. it will cost you some coin but you will sleep beter.
Of course you will have to deal with the Tow hitch and brake controller and trailer wiring hook-up.
Old 12-06-2013, 01:40 PM   #3
cpaharley2008's Avatar
I'd install helper shocks, the one with springs attached.
Jim
Never in doubt, often wrong
Old 12-06-2013, 01:53 PM   #4
Mike Magee's Avatar
Trailer: Li'l Hauley
If you push down on the rear bumper 3 or 4 times and let go, the rear should stop moving pretty quickly. If it keeps bouncing, the shocks are shot.
I put adjustable Rancho 9000 shocks on my Mountaineer a while back. I can set them firm for towing and light for everyday driving. They've held up very well.
How to prepare Tofu
Step 2: grill some meat
Old 12-06-2013, 02:49 PM   #5
When I first got my trailer I towed it with a 1998 Blazer. It's a great tow as far as I'm concerned. I stopped towing with it when I bought the Dakota. There was only one major problem when I sold it, the steering box was wearing out after only 215,000 miles. I couldn't really justify keeping it when I had the Dakota, other wise I would have had the steering box replaced.
Old 12-06-2013, 04:38 PM   #6
Trailer: ParkLiner
Virginia
I've only got about 92k miles on it and it is in really good shape; but being that old, I know I will have some failures.
Old 12-06-2013, 09:18 PM   #7
Roy in TO's Avatar
If I had a mechanic that only checked or maintained only half of the braking system, I'd be looking for another. Must be the origin of the phrase "a half-fast job".
shocks gdo Problem Solving | Owners Helping Owners 7 09-04-2013 11:44 AM
bounce... could it be bad tug shocks? Scott S. Care and Feeding of Molded Fiberglass Trailers 15 10-07-2008 05:46 PM
air shocks sherry loving o Modifications, Alterations and Updates 12 09-14-2008 11:01 PM
New shocks, springs- What do I need? Denise K Towing, Hitching, Axles and Running Gear 3 02-08-2007 12:40 PM
bounce... could it be bad tug shocks? Scott S. Towing, Hitching, Axles and Running Gear 0 12-31-1969 07:00 PM
