New Tug, have wiring ? - Fiberglass RV
Old 07-18-2011, 12:17 PM   #1
Tim Wood's Avatar
Trailer: Class B for now
NY
I'm getting a 09 Kia Sedona later today and have to put a trailer hitch on etc. I'm just wondering for those who have put brakes on their 13 Scamp,Boler etc, what did you use for a plug 7way or 5way ?
Old 07-18-2011, 12:23 PM   #2
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
7 way
Old 07-18-2011, 08:07 PM   #3
Tim Wood's Avatar
NY
Kevin thanks I figured the 7way, just wanted to see what someone else thought.
Old 07-19-2011, 05:00 PM   #4
Tim, you'll find the seven pin diagrams in the Document Center, both vehicle and trailer ends: Fiberglass RV - Document Center - Electrical
Yep, Kevin has it right.
Old 07-20-2011, 01:05 PM   #5
LukeP's Avatar
Iowa
Hey Tim, just a sidenote... I just installed a 7-plug as I rewired my Boler and I took it for granted that the standard wiring schematic would be "standard". Or maybe I should say that I "assumed" ... and we all know what happens when we assume! Yep, the plug's black wire went to the brakes, the blue wire to a turn signal, etc etc. STUPID me for not doing a 30 sec check with my meter BEFORE wiring it all up. It was a tense hour until the realization hit that it was the plug that was messed up - NOT the re-wiring job in the trailer! So, just a warning to double check that your plug you buy, actually matches up with the rest of the world's 7 plug standard. OH, and I have a brand TAP 7 wire plug, fwiw.
LukeP is offline   Reply With Quote
Old 07-25-2011, 06:38 AM   #6
Tim Wood's Avatar
NY
Thanks Donna & Luke, good info. I have the Tug almost wired just have to run a couple of wires to the front of the vehicle. And mount my p2 controller so I can make the last connections . Then I have to put brakes on the trailer next.
Old 07-25-2011, 07:23 AM   #7
Trailer: 2014 Escape 21
Virginia
Tim
I had the same problem with a pigtail that Luke had. I use junction boxes with my 7 pin pigtails, It really helps out in sorting out wiring issues and protects the connections. Redneck and E trailer sell the boxes for about $15.
Eddie
http://www.etrailer.com/Accessories-...tch/38656.html
Old 07-25-2011, 08:17 AM   #8
Meghan's Avatar
Trailer: Play Pac
I have wiring issues too. Can you link to those connectors, I don't know what I am looking for
Meghan is offline   Reply With Quote
Old 07-25-2011, 09:04 AM   #9
Virginia
Meghan
I added a link to my last post for the junction box. Check out the video. Even thought they are just dealing with brake wiring you do the same to tie your lighting, aux. pwr, and breakway wiring into the 7 pin pigtail. On my 13 Scamp I'm working on, I going to mount the box under the left side of the goucho seat base inside the trailer. Makes a much cleaner job than butt splices and it is real easy to troubleshoot wiring issues.
Eddie
Old 07-25-2011, 09:19 AM   #10
Meghan's Avatar
Trailer: Play Pac
Originally Posted by Eddie Longest View Post
Meghan
Eddie
Cool! Thanks!!
Old 07-25-2011, 05:35 PM   #11
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
Hi, all
Wise words!
Most of the "Fat and Flat(pin) 7-pin connectors on older trailers are old-style Bargmans, and the trailers are wired to match.
You need to make sure you've bought the right car-or-trailer pigtail/plug or be prepared to rewire what you did buy.
One source for an exact duplicate of both ends is Bargman 7-Way Cable
Francesca
Old 07-25-2011, 09:30 PM   #12
Tim Wood's Avatar
NY
When I bought my Scamp it had a 6 pin connector on it, I changed it to a flat 4. And now I'm going to put brakes on it so it will be a 7 pole. I just got done wiring up my Van today, I put on a 7 pole connector along with a P2 brake controller. Man that was a work out running the wires I had to underneath and up to the engine compartment. The hitch only took me 30 minutes to put on and that was the easy part. Eddie thanks for that link, it sure looks like a sweet set-up. I know that my trailer lights aren't the same color code as my vehicle, but I worked that out with a test light when I changed it from 6-4. Now I have the electric brakes coming Wed so I'll probably get to work and putting them on thurs/fri I hope. I shouldn't have much trouble with the wiring but that junction box looks like a cheap and good way to go.
Old 07-25-2011, 10:07 PM   #13
LukeP's Avatar
Iowa
I second Eddie's junction box! THAT was the only reason my fix was *relatively* painless when I discovered the pigtail didn't match the tow's wiring. And I put mine in the same spot... pretty close and easy to get at if needed.
Old 07-26-2011, 06:16 AM   #14
Tim Wood's Avatar
NY
So Eddie or Luke if you mount the box inside the trailer, how long of a pigtail do you use to get out to the tongue (8')? By the way I'm not planning on using a pigtail but I may change my mind . And does anyone have a picture of the mounted box inside ? And how do you wire in your breakeaway switch if your wiring is all inside the trailer ?
Wiring of a Scamp to a Tug? Al V Problem Solving | Owners Helping Owners 3 08-18-2009 01:01 PM
New Tug Taylor Kissinger Towing, Hitching, Axles and Running Gear 4 01-24-2009 08:25 AM
New Tug jimtesla Problem Solving | Owners Helping Owners 5 08-12-2007 06:04 PM
New Toyota Tug? Al Stansell General Chat 11 01-17-2006 09:59 AM
New Tug jimtesla General Chat 0 12-31-1969 07:00 PM
