New Years Resolution and Tongue Weight - Page 2 - Fiberglass RV
Old 01-02-2007, 07:49 AM   #21
Trailer:
That Sherline gauge looks like a wonderful piece of kit, but I would suspect the accuracy and price are more than is really needed for this job. In Yurp, we can buy the simple gauge on the left for $20-30, although I'm impressed by the idea of Winterhoff to incorporate a scale into the jockey wheel (the holdy-up thing at the front whose American name I've just forgotten....).
The noseweight (oops, tongue weight) guage is so simple - two pieces of tube and a spring - that you'd think someone might see this as a business opportunity.
Andrew
Old 01-02-2007, 12:17 PM   #22
Brian B-P's Avatar
I think that spring scale built into the tongue jack is genius, as long as it is not too "springy". The user must realize that the indicated weight is higher than the actual tongue weight, due to the position of the jack; however, this is just a constant multiplying factor so it is an easy correction to make.
The only issue I see with the separate spring scale is that it looks like it might not be adjustable, and yet the coupler must be at the towing height for the weight reading to be valid. Are coupler heights standardized in Europe?
And one more question... the Winterhoff site refers to "the new 100 kmph ruling": does anybody know what that is? Some sort of rule about minimum or maximum nose weight for operation above 100 km/h, perhaps?
Old 01-02-2007, 01:20 PM   #23
Con
Trailer: 1977 Boler 1300
Find someone with a platform scale for weighing livestock.
They run up to and over a 1000lbs.
We had a electronic one I built into our llama chute for when we did any vet work on the animals. We would weigh our llamas, dogs and cat every 30 days. If someone didn't believe a bale of hay weighed 65 lbs. I would the throw it in there and check the weight.
It cost us $1400 but it was well worth it.
Most farmers would be glad to help you.
Con is offline   Reply With Quote
Old 01-02-2007, 03:27 PM   #24
Trailer:
In Germany trailers can pass a technical inspection that allows them to be towed at 100km/hr (62mph) instead of the usual trailer limit of 80km/hr (50mph). I don't know all the details, but one thing they require for this is to have dampers (shock absorbers) fitted to the trailer.
Andrew
Old 01-02-2007, 07:07 PM   #25
Trailer: 1978 Volkswagen Westfalia
Dumb question - if your towing vehicle says it can handle 1,500 pounds - does that include all the people inside your vehicle too?
Jan Adams is offline   Reply With Quote
Old 01-02-2007, 08:41 PM   #26
Bigfoot Mike's Avatar
Trailer: Bigfoot 25 ft / Dodge 3500HD 4X4 Jake Brake
Here are some Terms defind. I hope this helps.
[b]Gross Combination Weight (GCW):
Total weight of a fully equipped vehicle and trailer with cargo, driver and passengers, fuel, coolant, equipment, etc.
[b]Gross Combination Weight Rating (GCWR):
Maximum allowable gross combination weight (GCW).
[b]Gross Trailer Weight (GTW):
The weight of the trailer plus all the cargo in it. This is measured by putting a fully loaded trailer on a scale.
[b]Gross Trailer Weight Rating (GTWR):
Maximum allowable weight of the trailer, plus its cargo.
[b]Gross Vehicle Weight (GVW):
The total weight of the tow vehicle, including driver, passengers, any special equipment (options, accessories and upfitted equipment), cargo, fuel, coolant, etc.
[b]Gross Vehicle Weight Rating (GVWR):
The maximum allowable total weight of the tow vehicle, including driver, passengers, any special equipment (options, accessories and upfitted equipment), cargo, fuel, coolant, etc.
Old 01-03-2007, 01:45 AM   #27
Brian B-P's Avatar
So to apply the terms which Mike defined...
1,500 lbs is the Gross Trailer Weight Rating. The people in the vehicle count towards the Gross Vehicle Weight (GVW) and the Gross Combination Weight (GCW); you might still be able to tow a trailer weighing the whole 1,500 lb even with a few passengers, as long as your GVW isn't more than the GVWR and the GCW isn't more than the GCWR.
For instance, the GTWR for my Sienna is 3,500 lb. I could carry several hundred pounds of people and cargo in the van before the total of everything hit my GCWR, or the weight of the van and contents (and hitch weight) hit my GVWR, but I couldn't carry as much as would be possible without the trailer.
For many vehicles, especially trucks, the GTWR is calculated assuming nothing but one 150 lb driver in the vehicle; in that case, the trailer rating (GTWR) looks really high, but in practice you would have to subtract the passenger weight.
So if you get all of the ratings for your particular vehicle - not just the GTWR - you can determine the answer... for that vehicle.
It's [b]not a dumb question!
Old 01-03-2007, 07:09 AM   #28
Roger H's Avatar
Uh... not to state the obvious here, Brian... but uh... that's what wood leveling blocks are for?
Sorry Brian... couldn't help m'self...
BTW, here's a link to the Sherline scale for $99.95
Going to my room now!
Roger
Old 01-03-2007, 11:47 AM   #29
Trailer:
Why?
I think it would be a help to many people to really be sure if the trailer's rockin'......
Andrew
Old 01-03-2007, 02:04 PM   #30
Brian B-P's Avatar
I realize that balancing hundreds of pounds of trailer load on a stack of scrap wood and a stick (the spring gauge) is typical of RV practice, but I like to do better. Rather than hunting for a scrap of just the right thickness, a height-adjustable scale would be nice.
Of course the bathroom scale approach has the same problem, but it is readily addressed by using an adjustable stabilizer stand between the scale and the coupler. Here's my Boler on my bathroom scale:
Perhaps it is an unfair stereotype, but I expected that the design of a German product (I was guessing - probably incorrectly - that the separate nose weight gauge was also from Winterhoff) would have addressed this functional issue; that's why I asked if there is a standard coupler height which would make adjustment unnecessary.
By the way, the separate gauge appears to be the one sold by suppliers such as Towsure (I don't know the actual maker), and handles only 80 kg (176 lb) - not enough for many of our eggs.
weighing, weight
tongue weight Rob M Towing, Hitching, Axles and Running Gear 10 01-10-2008 07:26 AM
Tongue Weight Chester Taje Towing, Hitching, Axles and Running Gear 26 07-03-2007 10:59 PM
Tongue Weight chemong Problem Solving | Owners Helping Owners 5 07-04-2006 11:59 PM
Tongue weight Jana J Towing, Hitching, Axles and Running Gear 20 05-31-2006 09:44 AM
Tongue Weight Chester Taje General Chat 0 01-01-1970 12:00 AM
