No Current to Brakes on Our New 2013 Casita - Page 2 - Fiberglass RV
Old 05-16-2016, 06:06 AM   #15
Paul O.'s Avatar
Trailer: '04 Scamp 19D, Tacoma 4.0L 4door, SB
ex VT, now CO
Originally Posted by Jack L View Post
Your brakes may be just fine. Let me TRY to explain. When you energize the brake circuit, a magnet "grabs" the drum on the drum face surface. Then the magnet holding onto the drum engages the brake shoes. The forward rotation of the drum is what puts pressure on the shoes. For the brakes to work, the wheels have to be turning. I know you said you spun them, but maybe not enough. If you are getting power to the magnet, hitch the trailer up and drive forward. When moving slowly, you should be able to feel the brakes working as well as hear the noise of the shoes contacting the drum. Hope this explains it and helps .
This is a good explanation of how it works, but I wish to make a minor correction, if you don't mind. The magnet sticks to the face of the drum immediately, regardless of rotation. The rotation moves the magnet, the lever on which it is mounted and that lever spreads the shoes. So you can test it all after jacking up the wheel (taking all necessary precautions, of course!).
Old 05-16-2016, 06:25 AM   #16
CPW
CPW's Avatar
Trailer: 2015 Escape 5.0TA
Post deleted
Old 05-16-2016, 07:40 AM   #17
Mr Lynn's Avatar
Trailer: 2013 Casita Spirit Deluxe 17, purchased from original owners May, 2016
Massachusetts
Originally Posted by Raz View Post
To measure current requires that the current flow through the meter. Sounds like you were doing voltage measurements ??
Pulling the break away switch will power the trailer brakes with the trailer battery. If the brakes engage then you have eliminated the trailer brake wiring as an issue.
To test the brake controller you can look for a voltage at the brake pin on the 7 pin plug at the rear of the tow vehicle while a helper manually activates the controller. If after adjustment you can't get a voltage there you may need to call the Ford dealer.
I was using a test light, not a meter. I can use a meter on the brake pin—but would I see any voltage when the trailer is not connected? Certainly didn't light up the test lamp when the brake pedal was pressed, even though the light pins were hot.
I'm going to go out on a quiet road and test the controller/brakes and see what happens.
/Mr Lynn
"The Molded Fiberglass Obsession"—From a Pickup Cap to a Casita
"Hillbilly at Harvard"—Honky-tonk Country and Bluegrass
Mr Lynn is offline   Reply With Quote
Old 05-16-2016, 09:11 AM   #18
Mr Lynn's Avatar
Massachusetts
Good News!
Good News! The brakes ARE working!
At the highest gain (10.0) driving slowly, I was able to lock up the brakes using the manual actuator (the squeezy control). Then I reduced the gain and settled on 7.0 for now, which seems to provide braking without lockup.
So I think we can say that the electric brakes are working. With the manual control I can feel the trailer brakes without touching the Expy's.
Thanks to all, but especially to Steve Dunham for this tip:
Your factory brake controller is proportional and increases the braking power based on speed and forward momentum. Since you are parked and not moving the brake controller will sense this and send little power to the trailer brakes when the brake pedal is pushed. . .
I'm tempted to have a shop go over the brakes and bearings, though; wonder if my auto mechanics will do it. No trailer shops in our town.
But for the moment, I think we're in business!
/Mr Lynn
Old 05-16-2016, 10:25 AM   #19
Trailer: Casita 17 ft DLX SD
GREAT NEWS . Go camping and enjoy yourself. There is always a great sense of satisfaction when you solve a problem on your own with a just a little bit of guidance. I too have my gain set at 7.0 and it works for me. CONGRATULATIONS.
Old 05-16-2016, 10:36 AM   #20
Trailer: Bigfoot B-17 CB
Yes, I thought that is what I did say. For sure that is what I was trying to say. The point I was trying to make is that some substantial wheel turning is required to get breaking action.
Jack L is online now   Reply With Quote
Old 05-16-2016, 02:11 PM   #21
Raz
Raz's Avatar
Vermont
/Mr Lynn
Good idea. Any good mechanic can grease your bearings and check the brakes. Better than an RV shop in my opinion. Raz
brakes, casita
Historical frame damage, current condition and my current plans Randy C in Ontario Problem Solving | Owners Helping Owners 3 06-16-2014 09:08 AM
MI | 2013, Sept. 6-8: Michigan Algonac Egg Scramble 2013... PaulOWindsor Rallies, Get-togethers, Molded Meets (Archive) 235 01-10-2014 09:00 PM
OR | April 25-28, 2013: Spring NOG 2013 – Northern Oregon Gathering Donna D. Rallies, Get-togethers, Molded Meets (Archive) 192 04-30-2013 10:12 AM
TX | 2013, Dec 5-8: Matagorda Madness 2013 JackieE Rallies, Get-togethers, Molded Meets (Archive) 2 03-24-2013 11:01 AM
1985 CASITA Houston-North Branch current bid $25.00 Kevin K Classified Archives 7 03-22-2012 05:52 PM
