Old hitch and sway bars - Fiberglass RV
Old 07-29-2008, 08:58 AM   #1
Shelley's Avatar
Trailer: 1977 Triple E Surfside
My Surfside came with a larger, heavy hitch and some sway bars. I'm wondering if there is any advantage to using them? I have tried to follow the sway bar topic but it seems to refer more to newer equalizers/wdh etc. And if there is an advantage - what is the correct way to attach the bars?
I'm towing with a 97 2dr Ford Explorer (shortish wheelbase).
Thx!
Shelley is offline   Reply With Quote
Old 07-30-2008, 12:04 AM   #2
Pete Dumbleton's Avatar
Since you have them I'd install them -- Not needed but I think you will find towing is a lot smoother.
Go to hitch manufacturer's web site and download instructions or call 1-800 number.
Old 08-09-2008, 10:41 PM   #3
I might add that using spring bars rated significantly higher than your tongue weight can lead to frame or trailer tire damage if you equalize the entire hitch weight, and transverse concave road conditions (dips, entering or leaving ramps/driveways, etc.
The relative angle of the TV vs. the trailer causes the spring bars to WAY over equalize the hitch weight to the point there are many examples of the chain saddles or the trailer frame failing.
You CAN get lighter spring bars for most WDHs.
Bob
bobinyelm is offline   Reply With Quote
Sway Bars Victor Benz Towing, Hitching, Axles and Running Gear 20 01-28-2010 08:50 PM
Sway bars. The Hobo Towing, Hitching, Axles and Running Gear 7 12-31-2008 12:56 PM
sway bars, equalizer hitch Francine P Towing, Hitching, Axles and Running Gear 18 11-14-2008 12:10 PM
Sway bars-continued Legacy Posts Towing, Hitching, Axles and Running Gear 6 07-29-2003 06:50 AM
sway bars, equalizer hitch Francine P Problem Solving | Owners Helping Owners 0 01-01-1970 12:00 AM
