Parkliner Coupler - Fiberglass RV
Old 09-23-2016, 01:20 PM   #1
Trailer: Parkliner
Virginia
Parkliner Coupler
We're stocking up with our initial "stuff" in anticipation of the delivery of our new Parkliner in a month or so.
We have a questtion: Does the Parkliner use a 2" raised latch or 2" Atwood yoke coupler?
Thanks for any help you can offer!
iamjiwjr is offline   Reply With Quote
Old 09-23-2016, 06:01 PM   #2
frank_a's Avatar
Trailer: 2012 ParkLiner #006
Bet you folks are excited!
I'm not real sure I understand the question. You just need a 2" ball on your ball mount and you'll be fine. Ours is a 2012, and has a triangular tongue. We removed the hand crank jack and installed a power tongue lift.
But in terms of what you need to tow, it's a 2" ball in a ball mount that will allow you to tow with the trailer being as close to level as possible.
Good luck!
Frank
2012 ParkLiner #006
Old 09-23-2016, 07:03 PM   #3
Trailer: Parkliner
Virginia
Thanks for the reply. i guess I could have given more information. The tongue lock we're buying requires us to specify the type of coupler. That's the reason I was asking.
Thanks again so much for taking the time to respond!
Old 09-23-2016, 07:09 PM   #4
frank_a's Avatar
Aha! Now I get it.
We use a 6 pin hardened steel padlock through the safety pin holes of the coupler. I use the same sort of "security" on my big 6X12 utility trailer and our boat trailer. Plus it doubles as a safety pin.
Enjoy your new trailer!
Frank
2012 ParkLiner #006
parkliner
1982 Burro Frame welded, new coupler installed MikeCM Modifications, Alterations and Updates 2 09-29-2009 07:21 PM
coupler height cyndi H Towing, Hitching, Axles and Running Gear 18 05-04-2008 05:52 AM
Boler Hitch Coupler A. Robert Reed Problem Solving | Owners Helping Owners 2 08-14-2007 05:46 PM
Coupler Concern Chris73 Towing, Hitching, Axles and Running Gear 7 07-30-2006 03:26 PM
coupler height cyndi H Problem Solving | Owners Helping Owners 0 01-01-1970 12:00 AM
