09-22-2014, 07:59 AM
#21
New Jersey
Roger, its real marine plywood with several coats of varnish to seal it.
deryk
09-22-2014, 08:52 AM
#22
Trailer: 2012 ParkLiner #006
Even marine plywood should be sealed with something like 3M 5200. Better safe than sorry, and it does not cost much.
Frank
2012 ParkLiner #006
09-22-2014, 09:59 AM
#23
Originally Posted by Sid
I tried to decider that one from my vin number a while back. All I can tell you is that I have the 14 vin number issued in March of 2014. My bet guess it that it is somewhere between #60-#70.
If anyone could help me narrow it down I would be intrested but it isn't killing me.
Sid
Sid, I don't believe the sequential build number is stamped on the trailer. I think the only way to get that information is to ask the factory. Since you are the original owner, it shouldn't take them a minute to check their build schedule, find your name, cross reference to the build number, and tell you what your build number was. I think. If nothing else, it's kind of cool just knowing it.... Dale
09-22-2014, 10:03 AM
#24
Ask the factory all you want folks, but it appears they did NOT keep records. At least that was what I was told. They have no idea what # any of these trailers are, no records. Amazing isn't it?
On the other hand, after dealing with them, I don't doubt they would tell you a number just to keep you happy!
Frank
2012 ParkLiner #006
09-24-2014, 10:11 AM
#25
Trailer: Chevy AWD Van Conversion
Astoria Oregon
Parkliner fixed!
looks great, nice simple mod. I'm thinking of going a similar way just cuz our van now has such nice ground clearance (lifted a bit last spring)...and also...i just like the more "Off Road" capable look of a lifted rig (van/truck) and trailer to match. My one gripe on the PL design was there was no "Off Road" option to lift it from the factory...The stock PL's look quite nice in a low-rider parade
Happy (higher) Trails!
Thom
09-24-2014, 10:35 AM
#26
Is the area circled welded? I was trying to figure out if the axle drops straight down, or slides out sideways with square tubing nested inside square tubing?
09-24-2014, 02:26 PM
#27
That's the mounting flange on the axle. It's bolted to an L shaped flange welded to the frame. The frame flange has a cut out to accommodate the axle tube. I have the same arrangement on my Trillium.
Looking at that picture, one thing I would recommend is some sort of water proofing on those brake wire crimp connectors. They won't take long to corrode with the ends exposed. Raz
09-24-2014, 02:48 PM
#28
Ya gotta love ParkLiner. The owner (Chandler) told me not too worry about those unprotected crimped on connectors under the trailer. I did a double dose of Liquid Electrical Tape on all I could find once I got my trailer back from the factory. There's a bunch of unprotected crimped connectors under the trailer, 2 on the right and a bunch on the left. Raz is exactly correct - unprotected, they will corrode quickly if the trailer is used much. Shoddy workmanship in my book.
Frank
2012 ParkLiner #006
09-24-2014, 05:51 PM
#29
Trailer: Parkliner 2014
Wisconsin
Thanks Raz for the waterproofing suggestion. I went out tonight and did every one that I could find. Better safe than sorry!
Sid
09-24-2014, 06:13 PM
#30
Astoria Oregon
i'm heading to HD tomorrow to pick up a bottle of liquid eTape and have a go at those twisted wires i see under there. good idea!
09-24-2014, 06:29 PM
#31
You can be sloppy with that stuff too Thom, though after years of use, I'm pretty good now!
I usually do two coats. You'll find it naturally wicks into openings (i.e., the ends of the crimped connections) the first time. I do two coats just because of my compulsive nature.
Frank
2012 ParkLiner #006
09-24-2014, 06:33 PM
#32
On a used trailer do you think maybe corrosion has already started. I would have cut off those connectors and replaced them with new ones that have heat shrink on them
09-24-2014, 06:40 PM
#33
Astoria Oregon
Parkliner fixed!
Frank...i used a similar product to waterproof all the electronics on our RC Rock Crawlers, i just didn't think of doing the same on the PL. Thanks for the polite Whack on the side of my head to do a good thing for the TT.
09-25-2014, 06:21 AM
#34
No problem Thom. It was one of the first things I looked at. I has asked ParkLiner to do something with them when it was down for the battery movement (and a number of other things that did not get done), but Chandler was not concerned with it at all.
Also, I have found over time that heat shrink tubing will dry out and allow moisture in. I've been using liquid e tape for maybe 20 years, and it does not degrade like heat shrink tubing will. I started using it on my boat restorations years ago, and now use it all the time on about any 12V connections.
Frank
2012 ParkLiner #006
09-28-2014, 06:12 AM
#35
Trailer: Parkliner
Frank, I know you told me about this earlier, do you recommend a particular brand of e tape or are they all just about the same?
Thanks
Pat
09-28-2014, 06:29 AM
#36
The first one I ever used was Star Brite Pat, but my experience is that they are all about the same. I look for Star Brite when I run out, but can't always find it. Amazon carries it: http://www.amazon.com/Star-brite-Liq.../dp/B0000AXNOD
Take care and give those pups a scratch on the head for me would ya?
Frank
2012 ParkLiner #006
09-28-2014, 06:40 AM
#37
Trailer: Parkliner
Thanks Frank, I will order some today and get myself under that trailer and get that done before winter. I will give all the 4-legged kids a scratch from you……..
09-28-2014, 06:42 AM
#38
Sounds good Pat. At least with mine, there were two on the right side and 5 or 6 maybe on the left. They're not particularly easy to get to. It helps if the wheels are off when you're doing it.
I hope you and those 4 legged kids are doing great!
Frank
2012 ParkLiner #006
