Parkliner fixed! - Fiberglass RV
Old 09-18-2014, 08:37 PM   #1
DJO
DJO's Avatar
Trailer: Parkliner #40 something
Parkliner fixed!
Our local body shop has fixed our wheel rubbing. They came up with bolting a new custom made axle underneath the stock axle. No more tire rub, better ground clearance and it pulls better than ever!
Tom was great about staying the course and answering every call. Chandler came thru with covering the cost.
DJO is offline   Reply With Quote
Old 09-18-2014, 08:52 PM   #2
charlsara's Avatar
Trailer: 2014 Lil Snoozy
Great. How much weight did it add?
Old 09-18-2014, 09:16 PM   #3
Mike Magee's Avatar
Trailer: Li'l Hauley
That's the first trailer I've ever seen with a spare axle built in. But seriously, it looks good and your post is heartening.
How to prepare Tofu
Step 2: grill some meat
Old 09-18-2014, 10:44 PM   #4
deryk's Avatar
New Jersey
Awesome!
Now I have the flexrider axle (I think thats what its called lol) that is adjustable but with all my off roading it has no rub marks. But can I ask what it cost and what kind of axle you went with?
Thanks!
deryk
Old 09-19-2014, 07:03 AM   #5
widgetwizard's Avatar
Originally Posted by DJO View Post
Our local body shop has fixed our wheel rubbing. They came up with bolting a new custom made axle underneath the stock axle....
I dont get it. Help me understand. Why not just insert a lift kit between the frame and the original axle?
Retired from Orbital Machine Works.
Where is Jim now? Here.
widgetwizard is offline   Reply With Quote
Old 09-19-2014, 07:11 AM   #6
Look at the picture Jim, the original axle is welded into the frame
Old 09-19-2014, 07:19 AM   #7
deryk's Avatar
New Jersey
yeah it would be alot of work to cut the old one out, and raise it up. I will eventually when my axle sags of I can't purchase the parts to readjust mine I will probably do the same thing and be good for another 20 years. I kinda wonder why ParkLiner just didnt do the same thing... would have saved them a lot of time and money redoing the wheel wells.
deryk
Old 09-19-2014, 07:21 AM   #8
OK - now I understand, Thanks!
Old 09-19-2014, 07:24 AM   #9
Deryk, Is the axle installed in a way that it becomes part of the frame? Looks that way to me. Kind of a poor design if you consider the possibility of ever having to replace it.
Old 09-19-2014, 07:26 AM   #10
Alabama
I was under the impression from posts several months back that ParkLiner was going to stop welding the frame to the axle and start bolting it like I believe flex axle manufacturers recommend. This is ParkLiner #040. Can any more recent original purchasers share with us their ParkLiner camper # and if their trailer frame is welded to the axle (like in the photo) or bolted? Just curious....
Old 09-19-2014, 08:28 AM   #11
deryk's Avatar
New Jersey
Yeah mary and bob, mine is welded on that it would be alot of work to replace it...I think welding the 2nd one on right below it is a good idea...gives it more clearance. When mine sags over time because all axle's do eventually I will probably go this route if I am unable to get replacement parts for mine...
deryk
Old 09-19-2014, 04:32 PM   #12
Sid
Sid's Avatar
Trailer: Parkliner 2014 V6 Jeep Cherokee
Mine is bolted on and no rub issues. We got ours in May of this year.
Sid
Sid is offline   Reply With Quote
Old 09-19-2014, 07:24 PM   #13
Roger C H's Avatar
Smile Bolted axle
Sid, do you have any pictures? One picture is worth a thousand words, you know.
Old 09-19-2014, 09:16 PM   #14
DJO
DJO's Avatar
PL fixed
After many calls around the country and lots of research by our body shop the axle was made for us by a company in Texas. Sorry I don't have the name. The shop gave us a great deal and did the work for $1k.
The new axle is made out of thicker metal than the original. The original was welded to the frame and supports the floor so taking it out was not practical.
I guess it does add some weight to the camper (150lbs?) Good thing that it's down low. No more scraping going out of the driveway.
parkliner
ParkLiner Fixed tire rubbing and Battery box!! Gretchen Modifications, Alterations and Updates 5 11-10-2013 10:16 PM
Boler was rear ended - can it be fixed? Brenda M Problem Solving | Owners Helping Owners 19 07-19-2009 12:40 PM
My '82 Burro needs floor fixed or replaced, I need advise MikeCM Modifications, Alterations and Updates 5 03-11-2009 04:28 PM
I FIXED MY HEATER!!!!!!!!!! Flygal Modifications, Alterations and Updates 10 05-24-2008 10:05 PM
74 BOLER: I fixed the door gap. Jayson Wall Modifications, Alterations and Updates 3 05-18-2007 04:26 PM
