Possible bent Axle on 2014 Scamp 16 ft - Page 3 - Fiberglass RV
Old 01-25-2016, 10:41 AM   #29
A straight edge across each wheel horizontally, and measure across at front and rear from one wheel to the other works to check toe-in. Have also done it by spinning each wheel and scribing a line in the center of the tire and then measuring. I also have a spring loaded toe-in gauge but it's not as accurate if the tire or rim has some runout. I've only used the string method to check alignment of the drive axle to the steer axle on trucks. Later we got a straight edge with a laser pointer for that and it was more accurate.
axle, scamp
Axle bent? greenghost45 Towing, Hitching, Axles and Running Gear 9 05-25-2015 05:46 PM
Bent axle? Arno Towing, Hitching, Axles and Running Gear 15 04-15-2011 07:02 AM
17Ft Bigfoot Axle - bent? Dave_L Towing, Hitching, Axles and Running Gear 10 09-14-2009 12:04 AM
Bent Axle? Legacy Posts Towing, Hitching, Axles and Running Gear 3 08-04-2003 12:26 PM
bent axle? Legacy Posts Towing, Hitching, Axles and Running Gear 7 07-21-2003 11:18 PM
