Problem with Springs - Fiberglass RV
Old 11-12-2007, 12:30 PM   #1
Bobbie Mayer's Avatar
Trailer: 2011 Escape 15A
I hooked up my trailer to take it to AAA today to get the VIN verified again. I thought it was sitting at an angle in the garage but attributed it to the wheel jack being on one side. But hooked to the Forester it was also leaning to the right. So I looked underneath and saw that the metal piece that is shown in the picture below open was closed, so that the thingamjig was flatter against the frame (hard to describe but if it isn't clear I'll get another photo when it settles again.)
I figured I could drive carefully and after a mile or less the trailer was riding level. I checked at AAA and it looked as the picture shows. Yes, everything is pretty rusty but looks solid despite the rust, except I can't tell about this part. It's obviously sticky; I'm not sure how it is supposed to act. What do I need to do?
Old 11-12-2007, 12:42 PM   #2
Steve L.'s Avatar
Trailer: 2003 Casita 16' SD
That nearly vertical item is the spring shackle and it should move freely as the trailer is rocked. Sounds like it's bound up a bit. I'd try some oil at the inside and outside of the top and bottom bolts.
I suppose that ideally it would be nice to remove both the bolts and clean them up and reassemble but it might be a bear to get the nuts off the bolt and and bolt out of whatever they're run through. I think a little oil would do it and the pieces will slip more easily as you use the trailer.
Quando omni flunkus, moritati
Old 11-12-2007, 12:51 PM   #3
What kind of oil do I need for that?
Bobbie
Old 11-12-2007, 12:55 PM   #4
Brian B-P's Avatar
The shackle swings to allow the spring end move horizontally as the spring flattens (to compress as the trailer moves down) and regains its curve (when the trailer springs back up and the spring curves more). In the photo the shackle has swung to accommodate the spring flattening, which matches nicely with the observation that the same side of the trailer is low.
Sure, it could be that the pivot at either end of the shackle is binding, and not allowing the spring to pull it back to the normal position. It could also be that the spring is collapsing, and staying flatter under the trailer weight than it should.
If after lubricating and bouncing it appears the suspension moves freely, but settles back to this position, then I would guess the spring is dead. If it reliably comes back to level as it did after driving - and doesn't just stick at level occasionally - it was just a sticky pivot problem and the spring is fine.
Shackle pivot points often have grease fittings, and in that case a gun can be used to add grease without disassembly.
If the spring really is collapsing (probably not in this case), it's time for a new one... and the one on the other side should be replaced at the same time. Fortunately, leaf springs are cheap - a shop will likely charge more for the installation than for the springs themselves.
Bobbie - the description and photo are fine
Old 11-12-2007, 01:02 PM   #5
I suspect it is really collapsing as it settled as it sat in the garage. (Although then I'm not sure why it springs back up in travel.) I'll try lubrication first, though. What kind of shop do I need if it is the springs?
Bobbie
Old 11-12-2007, 01:09 PM   #6
John Perry's Avatar
Trailer: 1996 13 ft Scamp
Send a message via AIM to John Perry
Bobbie
Buy a spray can of WD-40 at almost any store and spray the heck out of all 4 shackles and that should loosen them up and let your trailer set and stay level.
$1.00 says that it is all you will need!
John
John Perry is offline   Reply With Quote
Old 11-12-2007, 01:11 PM   #7
What kind of shop do I need if it is the springs? Bobbie
A spring shop Benz Springs .... I guess it would depend if you're looking for a DIY solution or not. You might see if a utility trailer manufacturer in your area would be willing to work on your fiberglass trailer if you want to have the work done. I know an RV place probably would, but they're going to "stick" you too and springs are springs.
Old 11-12-2007, 01:11 PM   #8
John
I have the WD-40 and will try that before anything else.
Bobbie
Old 11-12-2007, 01:19 PM   #9
John Perry's Avatar
Bobbie
I forgot to tell you that WD-40 is a penetrating oil and will need a time to penetrate into the bushings around the bolts on the shackles so don't give up if it does not work instantly.
John
Old 11-12-2007, 03:20 PM   #10
Brian B-P's Avatar
I agree with Donna - this is a spring thing, not an RV thing. I would try, in order
  1. truck and trailer suspension businesses (such as Standen's, who supplied the original springs and axle for my Boler; this type of business often has "spring" in its name, such as our local City Spring)
  2. trailer manufacturing and repair businesses (have common trailer springs in stock and recognize what is needed)
  3. any random garage
  4. RV shop
Okay, that's not fair to the RV shops...
What I would prefer to do personally is pick up new springs and bolt them in myself. They could come from a spring shop, or some types of automotive and industrial suppliers (such as Princess Auto in Canada).
With any luck, it's just sticky shackle pivots.
Old 11-12-2007, 05:57 PM   #11
DanPatWork's Avatar
Trailer: 88 Scamp 16 ft
  4. RV shop
I agree completely here with the bolt them in myself. Cheaper is always better. Another possibility for a spring supplier in the U.S. would be a farm & fleet, or a Tractor supply. Measure the length of the spring from eye to eye while suspension is unloaded, as well as from the eye that is in the fixed position, to the center bolt of the leaf. Buy the springs to build the leaf pack, 2 grade 8 bolts and nuts, and new spring u-bolts with nuts. It sounds like allot but the satisfaction of not having paid for the labor can be worth the price of the parts.
One word of caution, "RUST", find the best penetrating oil you can, soak, wait, soak, and then breaker bars, for those of you who don't have access to the "Blue Wrench" (Oxy-Acetylene)
DanPatWork is offline   Reply With Quote
Old 11-12-2007, 06:37 PM   #12
If it comes to that, I'm having someone do it. I'm willing to make repairs that don't render it impossible to tow the trailer to someone else to fix the problem I caused. Other than that, no thanks. But I found a vendor and servicer of leaf springs in town so I'll call them if I decide it needs doing.
Bobbie
Old 11-13-2007, 06:05 AM   #13
Trailer: Boler 13 ft / 31 ft Holiday Rambler
Maine
Bobbie
A product call PB Blaster is about the best penetrating oil I have used to loosen stuck parts.
Gerry the canoebuilder
Old 11-13-2007, 08:17 AM   #14
Is that short for Peanut Butter Blaster? lol.
I'll look for it in case the WD-40 doesn't work.
Bobbie
Blue Springs! BOBSMITH Camping, Campout Reports 6 05-16-2008 08:29 PM
Helper Springs d_wildemann Towing, Hitching, Axles and Running Gear 9 01-06-2008 10:12 PM
HOT SPRINGS and RVs Byron Kinnaman Camping, Campout Reports 31 11-10-2007 10:21 AM
New shocks, springs- What do I need? Denise K Towing, Hitching, Axles and Running Gear 3 02-08-2007 12:40 PM
Hot Springs Tonight !!!! Legacy Posts General Chat 11 05-19-2003 02:42 PM
