Question for Snoozy owners about greasing hubs - Fiberglass RV
Old 03-30-2014, 10:58 PM   #1
Mike Magee's Avatar
Trailer: Li'l Hauley
To grease the bearings on the Snoozy, I see there appears to be a grease fitting under the rubber boot on the hub. What I'm wondering is how to access the fitting. Do I pull on the boot itself, or is it attached to the metal ring surrounding it?
How to prepare Tofu
Step 2: grill some meat
Old 03-31-2014, 05:33 AM   #2
Trailer: Escape 5.0 TA
W. Mass
Sounds like Dexter E-Z lube hubs, there is a Utube video on how to use them if you do a search. If that is what you have, you still need to manually take them apart to inspect the bearings and replace the seals, and repack yearly. The Dexter website also has a manual on their Hubs, it includes a section on the E-Z lubes.
Bob & Deb
padlin00 is offline   Reply With Quote
Old 03-31-2014, 08:44 AM   #3
Mike Magee's Avatar
Ok, thanks, I found a video and by appearance I think that must be the one. I see I just pry the rubber part out. It says to jack up the trailer and spin the wheel while pumping grease; that part surprised me (and makes the job less E-Z!).
The old Burro had Bearing Buddies, and that was a fair bit different.
How to prepare Tofu
Greasing bearings in fall Cathi Care and Feeding of Molded Fiberglass Trailers 14 11-04-2013 05:24 PM
Lil'Snoozy owners : please contact me AMSCRAM Problem Solving | Owners Helping Owners 90 09-16-2013 08:32 AM
Questions for Snoozy Owners ColoRockiesFan General Chat 3 02-23-2012 07:56 PM
Re-greasing UHaul CT Bearings KarenW Problem Solving | Owners Helping Owners 3 07-07-2010 09:17 PM
Re-greasing UHaul CT Bearings Chad S Towing, Hitching, Axles and Running Gear 0 12-31-1969 07:00 PM
